An electrical question.
sni-per
Midwest
Hey fellas. I'm in the process of building myself a welding cart. I will have 3 machines on it, including a 110V mig welder, a 220V plasma cutter, and a 220V tig welder. I will only be using the equipment in my shop, so once they hit the cart, it will probably be permanent.
My question is.... Instead of running a ground clamp for each machine, and stumbling over said leads, would it work to ground to my cart (steel) and then run a single ground lead from the cart to the work??
Doubtful that any 2 machines would be switched on at the same time, so would the ground lead be feeding back somehow, into the others??
