fletcher969
Hi everyone.
To make a long and involved story short, a neighbor of my father's had several grinders scattered around in a couple of shops on his property, but one caught my attention one day a few years ago as he and I were getting acquainted while making some rounds around his place. I made a comment about it looking exactly like a very well-used version of one I used to use when I was a teen working for my dad back in the '70s, missing right side guard and all, whereupon he told me my father had sold it to him over a decade ago. It was the same grinder! I thought it was sold along with Dad's business at the end of the '70s, so I was pleasantly surprised. Dad has since passed away, which has prompted me to remember that grinder on several occasions, so 3 weeks ago I decided to call up Dad's old neighbor to see if he would give me right of first refusal if he ever decided to sell it. He told me it quit running a couple of years ago, and I could have it if I dropped by and picked it up. I'm a bit sentimental, and I'd spent several years after school and on weekends with that thing, so I didn't hesitate, not knowing if it was salvageable or not. It didn't matter, but I figured I was in the market for a decent grinder anyway, and it might accidentally be a decent pick. I have a knack for fixing things others give up on anyway, so all the better.
When I got it home, I plugged it in and flipped its switch. To my surprise, it wasn't completely dead like I had expected, but instead it hummed and spun backwards (wired in reverse?) very slowly around 60-80 RPMs, and it would never wind up to full speed. No amount of manually spinning it in either direction, before or after power was applied, resulted in it "catching" and spinning up to full speed. From what I've read in the various forums -- mostly on this site -- it's likely a capacitor failure. Regardless, I've decided this grinder is well worth whatever effort will be required to restore it (sans the guard and side cover on the right side), so that's my plan.
I gathered the information off the nameplate (which is still hard to read), and here's what it indicates:
Baldor
Cat No: 8107W
HP: 3/4
Volts: 115/230
Phase: 1
Cycle: 60
RPM: 1725
Amps: 6.6/3.3
Frame: 524C (???)
Serial: 1070
spec: G8-1-11
The information on the nameplate seems contradictory. All indications on Baldor's site are that this thing should be an 8100W, not an 8107W (1725/1800 vs 3450/3600 RPMs respectiively). Has Baldor changed it model numbering since 1970? If not, that could be an issue given Baldor also indicates each model uses a different capacitor (at least with the modern versions). Also, the 8107W -- the newer model at least -- has a relay, whereas the 8100W does not. Nevertheless, I hope once I open it up I'll be able to compare what I have with the information available to me, and proceed accordingly. It also indicates a Spec# of G8-1-11 for which I can find nothing online except for one Google link where another guy describes his 8107W having that Spec number. I'd be interested in whatever information anyone can confirm or may contribute regarding this grinder.
Before I sign off on this first post, I'm curious what color this model Baldor sported when it was new? It appears to be of the gray variety (versus Vista Green), and I remember it being gray as a kid. I've read where Battleship Gray would be close enough, but I'd like to get something spot on if practical.
Anyway, I've provided a couple of pics. Winter's definitely here, and I don't have adequate floorspace I can heat in which to work on it daily, so I'm not sure how long it will take to complete the restoration, but I'll be sure to post pics of my progress, and inquire within as needed.
Baldor
Cat No: 8107W
HP: 3/4
Volts: 115/230
Phase: 1
Cycle: 60
RPM: 1725
Amps: 6.6/3.3
Frame: 524C (???)
Serial: 1070
spec: G8-1-11
