Not so bad on the inside. Actually, the lever and ratcheting action were working great.
I ran into a little problem with the detent ball. It didn’t look bad other than the finish, but was frozen. A quick chomp with a pair of pliers freed it up, only it sunk in and got stuck.
Thought the spring behind the ball was toast, but no, that wasn’t the end. Applied some light oil to soak in around the ball, and I went to work on it with a 1/8 punch, using light rapid blows. The ball and spring came back to life! I repeated the process to make sure any debris in there was broken up.
A flip of the cover plate revealed a WF-21 inside.
This is how it went into the vinegar. Most of the parts went in as well.
