+ and - bits
rvr6000
St. Paul, MN
Looking for suggestions on how to cure my better half of calling screwdriver bits "plusses" and "minuses". Figured there's no way she could get a square drive bit wrong.........nope.....it's a "box" bit.
Don't even get me started on how she reads a tape measure...."three lines past the big line".......hahahahaha.:headscrat
Will67
Hell's half acre
Lol
:lol_hitti
Had an arts class in high school (80s) and the teacher gave us an exam on reading a tape measure. I passes 100% and I say thanks dad for making me help you remodel the house as a kid. In college I had a roomate that would have failed that test. I am blow away by people that have NO mechanical aptitude at all.
NUTTSGT
Northern Central Ohio
We hassled a guy at work one time about his lack of tape measure reading skills that he went home that night from work, pissed off.
slip knot
Texas gulf coast
Bought my wife one of the easy read tape measures. The little marks are numbered as well. Real time saver for me. now if I can just teach her the skinny or fat part.
She also calls the bench vise a "table clamp" Took me a while to figure that one out!
Ray-CA
San Diego CA
I had a friend of mine call out measurements as "5-ft, 6 1/2 inches + a line" or minus 2-lines. He'd go to the nearest 1/8th inch and then say + or - how many lines. It actually worked out pretty well once I had the translation down.
Ray
Steevo
43.49600, -112.04300
Be glad that your wife tries at all.
Mine would just tell me there's a loose screw that needs fixing.
I'd be thrilled if she wanted to take something out to the garage, squeeze it in the table clamp and turn the minus screw or push it with a pokey tool.
garboui
Southern Ontario
Ray
This through me off a bit when i worked with framing crews for a very short stint. Though it would be called as hard or soft measurements instead. ie. 12 and 7/8" hard for 12 and 15/16"
green.bubbly
Lafayette, LA
Around here, a Phillips bit is called a four corner screw driver.
I despise tape measures with the fractions written on them. My eyes make me want to go to the nearest mark with a dimension written instead of the actual measurement.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
My wife knows the "slot" and "phillips" but I always call a slot, a "Standard". She corrects me everytime. :mad:
greaseyjockey
sc
Print this out, and glue it to her makeup mirror. ;)
http://en.wikipedia.org/wiki/Phillips_head#Phillips
Thanks for that link, I'm an Automotive tech and I use multiple types of fasteners and bits every day and I thought I had a pretty good collection of bits. Granted I'll probably never come across a TP3 head, or a pentalobe, but if I do I'll know what to call them. Good read.
