And so it begins: 50x140
mkarlin
Northeast
Clapboards continue to go up
Filled and sanded the nail holes and a coat of primer for the faux doors
Also an interior shot of the inground lift
Next week final grading and foam, wire mesh, and radiant tubing
Little nervous about timing since I need to get it all done before sept 9 since the concrete guy is coming that day
mkarlin
Northeast
Teaser!!! Spent the last two weeks getting the floor ready for concrete in thursday!
Did the radiant heat with my wife’s cousin and help from the wife and in-laws. Took three days to lay all the tubing. Some tubing is under the mesh becuAse I was worried about the control guys and the base is so dense was hard to remove lateral. Planning on a 5 in slab but the spots with 3 sheets of 6 ga wire mess and a little high dirt had me worries so ran it under.
Could not be happier
78SC4X4
Port Orchard Wa
That is an amazing amout of tubing........... Can't wait to see the rest of the system. Thanks for keeping us posted on progress.
loganb
Omaha, NE
Re: And so it begins: 6700sq ft
Awesome update...can't wait to see the time-lapse of the upcoming pour!
Sent from The Garage Journal mobile app
mkarlin
Northeast
Thanks Loganb. I see you are from Omaha. I am from Nebrasks (Columbus)
mkarlin
Northeast
Pressure tested this am. So far holding pressure.
Now to tidy up the sweeps and lines
mkarlin
Northeast
Time for an update- has been 2 weeks of all out.
Concrete is being poured in the morning.
Base solid, 15ml Stego vapor barrier, 2 in formular 250 XPS, 6 gauge wire mesh on 1.5 in bolsters with 5/8 in pex attached to the wire mesh.
5 in concrete slab, 4000 PSI
loganb
Omaha, NE
Yep, just moved into Omaha suburbs(Sarpy county) this summer after 5 years in Chicagoland. Wife and I are both from this neck of the woods and a forced job change gave us an opportunity to get back and closer to family!
Excited to see it with a slab very soon!
mkarlin
Northeast
The floor got poured, with only one hiccup
Background: 5 in slab, 4000PSI
base was very solid, I did the the stego 15 mil vapor barrier, 2in XPS, and the radiant tube placement to wire mesh (6 ga on 1.5 in bolsters) with and did the foam and 6 ga mesh. I zipped the pex to the mesh every 2 feet.
They had to bring in a pump truck, and unloaded 2 concrete trucks at a time in to the hopper.
When they were running the tubing for the pump truck, the disc/support they used to slide it started to catch on some of the tubes and broke some of the zip ties. Most fixed either with new zip ties or with a rebar gun, but two sections of tubing floated up right after the screed, and had to be tied back down.
(they used a laser screeder)
The concrete guy was originally going to control cut it but said he was worried about those two tubes that floated even thought they got tied back down, he was worried other zip ties could have popped. (I was also very concerned)
So we elected to not do control cuts. would rather have a crack than cut tubing.
The group said they were impressed with the prep. All the work of the subfloor prep, foam, and tubing was a family affair (three of use). I am a little disappoint with myself that the tubing floated and we could not cut the floor (but the radiant held pressure that is good).
But at least the mesh is in the middle of the slab, instead of on the ground.
All in all was good except for the control cuts.
I got alot of comments that I should have just stapled it to the foam.
I am sure I am missing something
More updates to come, it is finally feeling like a real building.
muckdp
Make sure you do your research on that Atlas scissor lift. I looked into doing a scissor lift, and decided the Atlas wasn't for me, and the other brands were too expensive. In my research I figured out that the Atlas was basically an overseas model that they import into the US. That means all the valves, fittings, electrical, hardware, etc, is all foreign, and not "US Standard". Not only does that make working on it yourself more difficult, but parts are a challenge to get even from atlas. I also recall being concerned about its reliability in general, though I can't remember why specifically. I ended up going with a traditional rotary 14k 4 post lift, and I'm glad I did. So just make sure you do your homework. That's a nice building, and nice setup, don't ruin it with a finicky breakdown-prone lift.
Good luck!
mkarlin
Northeast
Thanks for the suggestion, we ended up going with an inground 2 post 10K Challenger lift.
Here is an image without the arms, 2 days after the slab was pour (wetted down for the cure process).
Good luck!
78SC4X4
Port Orchard Wa
Thanks for sharing your experience. Tubing on top of the mesh would be more efficient than stapled to the XPS, but it's unfortunate that it broke loose on you. I think I will probably staple to the XPS and put the mesh above the tubing to be safe.
mkarlin
Northeast
Yeah in the future that is that I would do. And if you really wanted them in the middle you could zip tie them to the underside of then mesh. Would be a lot of bending over but not horrible
All in all the slab only got 4 cracks in it. Two that were 1/8 inch wide that I will
Seal/fill and two hairline ones
Not bad for no control joints
mkarlin
Northeast
Got some painting done
mkarlin
Northeast
Some updates painting pics
78SC4X4
Port Orchard Wa
That's pretty cool. Thanks for putting that together.
What is the wheeled screed machine. Never saw that before...... and it didn't hurt the pex.
mkarlin
Northeast
Hoping to have it all painted by Sunday. Fingers crossed
mkarlin
Northeast
Interior walls going in this week, updated electrical service getting installed and painting done
mkarlin
Northeast
Some updates, have been wicked busy. Getting the electrical done and interior walls are up
The workshop is getting its own 100 amp sub panel. The building has a 200 amp panels, also installing the three phase converter. (Not pictures)
Also got the exterior lights up
Insulation is the next step, not doing spray foam.
loganb
Omaha, NE
:drool:
Congrats! Looking awesome
mkarlin
Northeast
:drool:
Thanks Logan, I may live in the NE (northeast) now, but I am from Nebraska originally and Went to grad school at K-state.
loganb
Omaha, NE
Glad you headed south for grad school. Grew up in KS and went to State but currently am one of the neighborhood rebels in Omaha not cheering for the Huskers
brainypencil
Wow, Looking great!
