You’re doing the right thing by looking beyond whatever is available locally!
Much good advice here already, and I would also advise looking for known makes where feasible. If you can find a good supplier, then sometimes you can trust what they offer, even if it’s unfamiliar.
I’m assuming you are in the U.S? I’m in the U.K, but we share suppliers such as MSC and Zoro, both of who offer cutting discs. You may find that good quality discs from one of these suppliers, cost no more than poorer ones from a store with higher margins.
Are you cutting stone / masonry, or metal?
For the former, forget conventional discs. I do this work seldom, but when I do I only use diamond discs. They remove less material, and the disc doesn’t disintegrate as you cut, so they are way cleaner to use.
I use these Marcrist, but that might be a British brand. Anything reputable works.
For steel, I now only use these ”thin kerf” cutting discs. By minimising the thickness of the cut they reduce the cutting effort, and the dust, but good quality is more important than ever with these thin discs. Norton, Sait and Pferd have all been mentioned, and I can vouch for them all.
I’ve recently been using these 0.8mm Flexovit discs and they are great.
If I find a disc I like I tend to stock up, but cutting discs are susceptible to moisture, so I tend to vacuum seal my supplies!
If I get an urgent job, it’s great to be able to go to my stores and pull out a cutting disc, grinding disc, flapwheel, or wire brush, in whatever size I need, without worrying about the quality!
