Angle grinder + long shirt = oh Sh*t
Coolabah
2nd Floor, 3rd on the Right,Narooma, Australia
Ok so I know I've been told, as the rest of us have that you shouldn't wear loose clothing when using some power tools. I'm one of those people that sometimes has to learn the hard way :lol: So I'm out 1 work uniform shirt 1 t-shirt and a little hide off my gut other than that no big deal.http://s1077.photobucket.com/albums/w474/scottc785/
Ouch ! 8 inches lower and you might have been 8 :shocking: inches shorter :pimpflash
.... yeh I'm like you I often gotta find out the hard way... lucky you're OK
millertime
MinnE soTA
Yea and the ******* is my grinder isin't like a dewalt or milwauakee when you let go it shuts off. I have a Hitachi <which i like> but it has a slide button. it's on until you manually turn it off, so yea while this thing was chewing my shirt off I was making a hasty grab for the power plug lol.
Hobbit
Bama
Wrong clothing to wear. I once removed an old battery out of a 60's Ford and aparently got acid residue all over my gym shorts which were some kind of cheap synthetic material. By the time I put the battery down I was naked.
millertime
MinnE soTA
yea the wrong clothes for sure.....I can't even tell you though how many times I've picked up my grinder and not even given a thought to what i was wearing.....lesson learned
555
Nomad-Arkansas & Georgia
In the 70s my Brother in Law was enrolled in a heavy equipment mechanic course. It was the 70s and long hair was popular with his group until he got his hair caught in a cylinder hone one afternoon. The next day the entire class showed up with high and tight haircuts.
RobertMo1988
sounds like me last week, i was boring out this hole with a milwaukee magnum, 5/8'' drill bit(probably not the best idea) but as i was working the drill i pulled it out further than expected. It caught my pants ( dickie style, blue thin mechanics pants, came from a uniform company called cintas) but it grabbed my pants by my right knee and twisted my pants up. it ripped/separated the inseam apart from knee to knee, and lucky me i got nothing but a bruise. but i got a nice breeze for the rest of the day. the guys keep asking me where my stripper pants are
darkk
Willimantic, Ct.
Being an older body man / painter, about 35 years ago we didn't have light air buffers/grinders or miniature anything. We hand rubbed lacquer or used electric buffers. The buffers of that era were usually very big and very heavy (like 10-15 lbs ) or it sure seemed that way. I had a 50 foot extention cord on my grinder/buffer with the connection tied in a knot so it wouldn't pull apart. While buffing, the only way to avoid having the cord scrape across the freshly buffed area was to sling the cord up over your neck and down the trigger arm. We usually locked the trigger on because the machine is way heavy and your trigger finger tires very quickly. All of the afore mentioned is a big no-no. While I'm buffing away, the cord dangled a little to close to the paint and got caught in the buffing wheel. Needless to say this 15 amp 15 lb buffer grabbed that cord and made a very fast climb up that cord and trapped my hand against my neck with the cord wrapped around it and the machine barely turning and getting tighter by the second. This thing is literally choking me, I can't utter a sound and I can't shut the ***** off! And let me tell you, that motor is strong! So here I am stuck, I'm connected to a machine trying to choke me to death, and I can't shut it off so I start running to pull the cord out of the wall. Did I mention that I had a 50 foot cord attached? I couldn't exacly remember which socket I was plugged into (shop full of cars) and couldn't see where it was. So here I am, all tied in a knot with this thing sucking the life out of me, Im glad it's summer because the bay doors are open and I make a mad dash for the door. I'm running like hell hoping it un plugs before this sucker chokes me out. I barely made it....the plug pulls out of the wall just after it took me off my feet. I'm laying on the ground, still choking! One of the other body men sees whats going on and was already running in my direction with a pair of side cutters...I not only got choked to half to death by this damned machine, but I had all these little cuts and blood blister pinch marks all over my neck from my co-worker trying to cut the damned cord. I sat there in a daze for quite a while after. We made little metal tabs for our belt loops to hold the cord after that...no more of that damn neck choke thing......****! I got lucky that day for sure....
dirttracker18
Slate River, ON
Carharht style bibs while using equipment in the shop can be a lifesaver.
Working under a motorhome skirt with a cordless drill once. As I passed the drill out I touched the trigger. The bit grabbed my shirt sleeve (short sleeves) and twisted it up. I looked and felt like the bit was in my arm. My wife was nearby and I called her over to carefully flip the drill to reverse. I carefully backed it out to find it hand not penetrated my arm. My shirt was ruined and my bicep was bruised something nasty.
Could have been way worse.
cotjocky
We do this at the shop, but only with a heat gun when we are chasing trash in tint.
I've been fortunate enough to never really get seriously caught up in any moving parts, but did have a car come down and cut the very tip of my left index finger off from a body seam. Like a guillotine; it was gone. That sucked!
Bender78
Northwest CT
This is a pretty timely post for me as well, unfortunately. This past Saturday, I was using a 4-1/2 grinder with a knotted wire wheel to clean the base of my milling machine prior to paint. Apparently, my T shirt came un-tucked and the wheel grabbed it. :scared: Damn lucky for me that all that material was enough to stall a DeWalt grinder; I still got a bit of a rash across my protruding gut.
You just can’t ever be too careful.
Macgyver_ga
Canton, GA
I've done that before. I was working in the garage grinding something with the grinder in the winter wearing a hoodie. My hoodie now has a nice big hole torn out of the front of it.
Buckgnarly
VT
Knotted wire wheel taught me to wear a leather apron now.....shirt slows it enough to only give me a serious brush burn. Also why I NEVER use the switches that stay on, "deadman" style for me......;)
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I was wearing a sweater one day running a lather cutting some hardened tool steel. I had a red hot chip land on the sweater and next think I knew, my coworkers were beating on me. The hot chip caught the sweater fuzz on fire. As soon as it hit, it was a dull blue flame all over. That was the last time I wore a sweater.
1Garageman
Columbus, Ohio
damn, that's something I never thought of before!!!!!
glad you are ok! And made me think of what to wear
next time I use mine!
Macgyver_ga
Canton, GA
Same thing happened to me on Saturday, except I was welding. I felt some heat around my ankle, flipped up my welding mask and looked down and the bottom of my blue jeans were on fire. Oops :lol:
