Angle grinder question
Coach James
Sandhills of North Carolina
Don't laugh, but I was wondering about this. On my Hitachi grinder I have always used depressed center discs. Could I also use those with no depressed center? I don't want to waste $2 finding out it wouldn't work.
Thanks
Coach
rlitman
Long Island
Almost certainly yes. I've yet to see a guard that takes a type 27 wheel (depressed center) that does not take a type 1 (flat). The opposite is usually, but not universally true.
The advantage to a type 27 is that the nut is less in the way (so I'd pay a slight premium for these).
The advantage to a type 1 is that you can (but really should not) insert the wheel deeper into a slot (when cutting).
BD1
north side
They will work however it depends on the type of lock nut / nuts on it. Some require a flat type with a raised surface for the disc to fit in. So you may need TWO for it to work and HOLD it securely. Take your grinder with and do a test.
