Angle of socket/wrench just off a bit...
PickyinPA
Trying to remove a bolt requiring a 6" socket extension. But... The access angle is off enough that I can not get a grip on the bolt. Help?
gdocktor3
Connecticut
Here's the answer to all your problems
tonyprovo723
Possibly stack a couple of extensions together and get a degree or two of flex at each joint if you already have them.
KnurledNut
n/a
I was in a pinch once and needed a wobble extension.
I just took a cheap-no-name one and ground the drive end to a wobble profile.
It worked so well, it found a place in my box.
