Another 4x8 Precision Plasma CNC Build
N
NWill
Columbus, Ohio
Also, quick shout out to Ron @ Precision Plasma LLC. Most guys run the CandCNC package which has 3/8 shaft motors. Flashcut uses 1/4 shafts. Ron swapped out the pinions for me no problem. I was accidentally shipped the 3/8 coupler for the z-axis. No big deal. I simply asked Ron if I had the correct part number to order a replacement from Velox. Ron got back to me right away and rushed the part out this morning [emoji106]
N
NWill
Columbus, Ohio
Awesome, OP. This is a great project for a youtube channel.
Agreed. I love watching this stuff.
What do you guys pay for slats? I was quoted $153 for 9 20ft 11ga 3" flat stock. $180 total for them to cut them in half so I can transport them. Is 11ga good for them?
Gamble
CHITOWN
I got the standard software 6.0 with THC. I couldn't justify the curve text and shape library. It was pretty damn cool but it's an extra $800 for the pro. I can always upgrade a la carte. So far I'm a fan of Flashcut. I love that's it's USB, all in one, and can run on any Windows.
When I couldn't get anything to move yesterday, all it took was a 2 minute phone call to Flashcut and I was doing dry runs.
Ron, Zach & Anne are all great at flashcut. Seriously I bothered them so much and they were helpful every time.
There is a lot more to the full software than just the shape library and curved text.
The ability to turn height control on/off while cutting is a big one for me. So the torch won't dive in small circles.
Adjusting the voltage on the fly which I will also use.
Export as a DXF, this is big for me since i use lots of different software.
The ability to weld objects together in cad. This is a big one as i have it on my torchmate cad.
And not sure if it's a pro feature yet or out yet but they are working on being able to rotate the part in the CNC part of the software. Again this is a big one if you are importing or downloading a file that wasn't designed on flashcut.
Those reasons alone I'll be upgrading to the full software as soon as I get my machine up and running again. Waiting on a damn electrician.
I had someone give me an employee discount and cut my slats. 11 or 12 of them were $60 for 3/16" thick and about 24" wide. That was very cheap.
I just had my laser guy cut me 6 of them roughly the same size and that was $60.
They don't need to be too thick or too thin. 1/8"-3/16" is perfectly fine IMO
N
NWill
Columbus, Ohio
Haven't accomplished much lately. Bachelor party + friend in town for a week = worthless.
Finally back at it. Currently cutting slats. And slats. And slats.
N
NWill
Columbus, Ohio
Ready to put slats in but the water table is warped from the 4th side being welded on. Any ideas how to fix this? I have an oxy/acetyl torch but no rosebud. Propane flame thrower thing but probably not hot enough. Maybe add some 2x2 steel to the underside between the cross braces so I have more to weld to and bring it flat? I should have this thing done today but now I'm stuck
Here you can see its high on left and low on right. Ideas?
N
NWill
Columbus, Ohio
Well I haven't updated in a while, I've been busy :) I got the table running a couple days after my last post so almost a month ago. I've burned through about 5 4x8 sheets and a bunch of drops so far. Here are a few random things I've made.
7cca39415b422e5c125b635dee8510d9.jpgda2622be6932be253635f1d7b1b0a566.jpg26756858b0a013a8a967a65b75636b97.jpgefb5273a06eaff95fa434d001f45c586.jpgc3294d1f29a1b4229d8315871b66c870.jpg3582e5ac7601d942b75c6cf5a079c8be.jpg37c1662ec6c36cbf3a13b42b950000eb.jpgc41477d280adc07ccb91eba2a854e77c.jpgbda32938f7001e460b0d9e6a63ce8e1c.jpg6680a7c6ee212700d766a725a8362524.jpgb251cf09cd33f6db21ead9175c54c9f6.jpg
N
NWill
Columbus, Ohio
Thanks all
Nice job...gets pretty addicting eh?
No kidding! Your thread and others on here were my inspiration to take the plunge. I was originally going to order one from LDR but they were 10 weeks out. I figured I'd try to beat that and I'm glad I did.
kazlx
Tustin, CA
You'll find it changes the way you build things. It's easier to draw a file and run to the table than other things, so you go that way a lot. You'll start thinking of how to make everything from flat sheet haha. It's really cool when you get beyond flat parts and start bending and folding. Being able to draw everything out and add in bend lines and not have to drill holes is the best.
N
NWill
Columbus, Ohio
Yep that's when it gets really fun. That fire ball thing was probably one of the most fun things I have ever built.
My fiance was asking me about a piece of base trim that needs replaced the other day. My first thought was how to make it on the table :lol: It would be much easier considering this table consumed my woodshop.
04chase
SO CAL
any pics of the water table ? how high are you running the water from the bottom of the cut? im building a 5x10 now and have to build the water table still and havent comitted to an exact setup .
N
NWill
Columbus, Ohio
I did mine similar to kazlx. I welded about 70 pieces of angle iron cut at 12.5 degrees. I used 3" 11ga for the slats cut about 1" long so they bend. I set one in place and used my angle finder to get the 12.5 degree angle.
My table is 11ga bent on 3 sides and welded on 4th, 4" deep. I had a bunch of 2' pieces of .5x.5 stainless tube I set in pan to raise slats. This gives me .5" under slats and above slats for splashing which hasn't been a problem at all.
My water depth is one thing I actually forgot to check on. What are you other guys running? I cut 99% 11 and 12ga steel. I think I'm maybe 3/8" under the work piece. This is just where it ended up...I need to research that. This could be low and why I get zero splashing outside of table.
N
NWill
Columbus, Ohio
I also just picked up a HF cement mixer. What are you guys using for tumbling media? I've been cutting a lot of small letters and removing any remaining dross is time consuming with 40 or so parts
kkroger
I don't tumble we just use a knotted cup on an angle grinder or I just buzz it off there with a 36 grit flapper. I'll put up some pics of our stuff later on....
N
NWill
Columbus, Ohio
I was using flap wheels but they add up quick. I recently switched to a cup wheel on a 6" Metabo and it works very well but it's a little sketchy trying to hold a part with one hand and too time consuming using a vice. I may try a strong magnet to hold the piece or try cup wheel on the lighter HF grinder.
It's has only been an issue when cutting a ton of 4" letters.
Crusarius
Upstate NY
set up stops on the table to press the plate against. As long as you grind the correct direction that works beautifully.
kazlx
Tustin, CA
If I was going to do anything different with the water table, I would have made the sides higher so the slats are actually lower than the sides. The one thing I hate about my table is the mess.
Edit: For dross, I also use a knotted cup on a 4.5 angle grinder. I've been meaning to get a tumbling setup like the HF mixer, but space is a premium and I don't do a ton of smaller parts that often.
kkroger
We use a steel bench as a grinding table and clothespin clamps or Vise Grip quickie clamps The Vise Grips we put a stick on felt foot on them to avoid marking the material since we go straight from grinding to finishing with ONLY AIR after grinding... I do things made from 18 Ga up to Half inch plate this way... Dialing in the table to all but eliminate Dross is key, on 18 I run at 300 IPM, I DO NOT have time for DROSS... on 3/16 I get a bit in the tighter corners and I have to hit it with a grinder for welding and I use P&O because I don't have time to acid etch EVERY part... I do a lot of aluminum parts lately so I have a bit of a different method for that a not knotted cup, softer etc... looks OK... I am generally coating everything and just so you know this is a two man shop, and we are using 2000# of 18 Ga a week. and Plate less often. I seldom use 14 or 11 but when I do it is generally smaller letters and such.. 2" or less...
kazlx
Tustin, CA
I use a 2'x4' traction mat, like the kind you stand on, but no holes. It's kind of rubbery, so it's basically non skid. The pressure from pushing down with the grinder pretty much keeps pieces in place. It nice because there's no clamping and I can move pieces around easily so I don't have to reach. I usually do a knotted wire wheel then finish up with DA sander and 60 grit. I also have an air Angle due grinder with 80 grit rolocs for cleaning up stubborn boogers or pierce points.
kkroger
These all have various methods of finishing, but All were deburred with a Knotted Cup or a soft Cup... Some have a grind pattern done with Flappers, I have a grocery cart full of used flaps, and I order them by the hundreds.... Usually from Roark Supply...
kkroger
Usually Prismatic Powders Clear Vision High Gloss Clear Powder coat... Cured for 20 minutes at 375... That is 20 minutes after everything hits temp... all of the finishes are powdercoated, regardless of color or what have you...
