Another compressor question...
white64
There is a Campbell Hausfeld Compressor for sale. It's a 5hp, 80gal, 2 stage compressor. The guy selling it described it as a 3phase motor. But, when I look online for the model # CI053080VA, I can't seem to find it.
I can find similar C.H. compressors and the electircal supply is described as 220-240 / 460... does this mean it is indeed a 3 phase or that it can also run on single phase 220-240?
Some smaller compressors are rated electrically as dual voltage 110/220, so it makes me wonder what the meaning is of the "/" in the case of this particular compressor.
Thanks.
Zrexxer
Pflugerville, TX
I don't think that particular compressor was sold as a three phase model originally, but motors can be changed. The only way to know for sure is to look at the spec plate on the motor.
Biff20
Lake Elsinore CA
when i was shopping for compressor, i found a ton of motors that were single and 3 phase all within the same model compressor. So i think you'd really have to see the motor plate like Zrexxer said. Grainger and McMaster Carr both sell electric motor fairly cheap($250-$380) for most 3-5HP single phase compressor motors. As for the dual voltage, I have a C.H. that is 110/220. Im not too sure about 220-240/460, but that last time I bought an item that had the voltage rating, it was 3 phase. I'd guess that it is 3 phase. Also, drop the letters of the part number and you can generally find it. McMaster.com, Grainger.com, NorthernTool.com should all have a search window. http://www.mcmaster.com/#electric-motors/=bjm5v6 <----look at the right motor. it has the rating you're asking about, and it's 3 phase
Greatbear
Columbia/Fulton, MD
The motor in the photo is definitely three phase, there are no capacitors or a large capacitor box that you'd find on a single phase motor. If a motor is rated 208/240/460, it's a three phase motor, it can only be run on single phase with a rotary or electronic phase converter. You will also need a magnetic starter as well.
Zrexxer
Pflugerville, TX
Ya mean like this???
Which could very well contain something like these?
