I have a Jenny single stage GU pump that I converted to electric from a gasoline engine. When doing so I did some research regarding the unloader. The gas was set up as continuous run and my electric is set up as start/stop. I forget where I got the information but it led me to believe that I didn't need an unloader on the pressure switch. I recall reading that the unloaders that are built into the heads of these pumps relieve the pressure when the pumps shuts off so a separate unloader on the pressure switch isn't required. The compressor ran fine. It always started without issue etc. Recently I had a motor issue which I'm ironing out but, while waiting for a couple of parts, I had this unloader thing pop into my mind again. I've seen many units pictured without an unloader on the pressure switch so I'm thinking I'm OK with my current set up but wanted to see if anyone here has experience with such things. My pump is no longer mounted to a tank. It sits on the floor and is plumbed to a tank that's about 8' above it.
Thanks
Galaxy S4, Slimkat
If I wasn't married I'd quit fishing
Thanks
Galaxy S4, Slimkat
