another Dayton Heater Question
bubinga
Hi, Hi Have The 5,000 watt max Dayton heater in my garage,
I wanted to take it down and make sure it is wired at max 5,000 watts.
But before my short *** has to stand on blocks and take it down,
Thought Id ask,
Is it wired to max heat Default 5,000 watts from the factory?
I cant find the book either, cause of my "No Count" Helper.:willy_nil<<< HIM
Thanks
edit.....edit edit again.........It's the
Shown Below, Same Difference as Dayton IIRC?
https://www.amazon.com/dp/B0000AXEZV/?tag=atomicindus08-20
Stuart in MN
Minneapolis
The instruction manual in this link says, "Heat output can be increased or decreased by switching wires at the wattage change terminal board. The heater is factory wired to deliver a heat output of 17,065 BTU per hour."
If you compare the BTU rating to the wattage rating on the same page of the manual, this means it's factory wired at 5000 watts.
bubinga
OK, THANKS Stuart in MN:thumbup:
Todd.Brock
Cincinnati
I believe that MEP makes both the Fahrenheat andthe famed Dayton G73. I have one sitting in my garage. When I installed it , it was wired for full burn from the factory.
Todd.Brock
Cincinnati
I was never fully in love with the heater. It does heat up , but I never had insulation in my ceiling. I am working on that this winter.
6PTsocket
Thought Id ask,
Thanks
Do you own a clamp on ammeter? Can you get access to the wires that feed it, more easily than pulling it down? At 5000 watts it should pull 20.8 amps running on 240 volts, and 10.4 amps at 2500 watts.
Falcon67
Merkel, TX
You would not have to take it down anyway - all the wiring is under the bottom panel. Those all come wired - AFAIK, mine did - at max output.
