snowdust2
I have been reading for awhile, but I can't figure out what I should do. Currently I have a 200a panel at the house with a 100a subpanel off of it. In the subpanel there is a 50a breaker that runs about 125' to my detached shop in conduit. Wire is THHN #8 and #10 for the ground. Shop has a small panel with a 40a breaker. The shop started as a detached garage that just needed power for lights and outlets. I now added onto it and will need more power out there. Just a hobby shop with 6hp compressor small welder and the usual other stuff.
I'm going to trench water this summer so I'll add another run of electrical then. Does it make sense to have a second panel out there for the second run? If I were to use the same size wire as the current run, could I just use a single panel and maybe a 60a breaker? To make it a little complicated, the next run will be more like 200' as I need to trench around the septic field lines for the water.
This isn't my area of expertise so any feedback is appreciated!
