I know there are a ton of these but I just can't seem to find quite what I'm looking for.
I'm closing on a used house next month, about 7 years old, 3 car garage floor is dirty but good condition, no stains or surface issues.
I can rent this floor grinder locally
http://www.sunbeltrentals.com/Equipment/equipment.aspx?itemid=0320070&catid=s340
I don't know what brand it is.
my question is, what is the prep order with a grinder? Do I wash and then degrease then grind? Then after the grind how do I prep? Wash and dry or is there a better way to get rid of the dust? Or do I just grind straight away until the surface is rough then roll out the epoxy coat?
what are you guys doing around the steps up to the house, just mask and paint around or remove them and replace when dry? I haven't looked to see if there's an easy way to remove them, probably isn't.
thanks for the advice!
