I'm putting up a 30x48 garage/shop. I want to put a 100 amp service is it. I have a 200 amp panel in the house with plenty of load to share. It'll be around 75' panel to panel. I live out in the middle of nowhere. They don't do permits here but I want to do it correctly.
I've tried several online calculators. They show anywhere from 1 gauge to 3 gauge copper and 1/0 to 3 gauge aluminum. I'm ok with using either. I do like the idea of copper better but aluminum is cheaper.
To answer you're question yes I do need 100 amp. I probably should have bigger. For 220 loads I have a mig welder, 2hp mill, 1 hp lathe, 5hp compressor, maybe an oven someday, but the real kicker is my Lincoln idle arc 300 tig welder. It calls for a 80 amp breaker all on its own, not that I run it wide open all the time.
What type of wire and size would you recommend? It can be direct bury wire or run in conduit.
Looking at mobile home feeder it only comes in 2/0, 2/0, 1,4 a couple places do list it in 2/0, 2/0, 2/0, 4. If I go with 2/0 I think I should step up to 125 amp panel but then I need to look and see if I can even put a 125 breaker in my box. If w keep it 100 amp could I run the mobile home wire with the 1 Guage nutral or would I need 2/0? The reason I ask is 1 gauge aluminum should be big enough to meet code but it's smaller than the hot wires. I will have more load on 220 than I will ever on 110.
Sorry for the long rambling post I'm just having a hard time rapping my head around what I really need for my service wire.
