Sorry to start yet another, but it seems that these get pretty specific to each situation so here goes:
I live just north of Chicago. Current temp this evening is -6F, thats pretty cold for here, but not uncommon lately.
I just bought a new to me house with a 3 car garage. I'm in the process of fitting it for a woodworking and bicycle repair space, but it is currently 20 degrees in the garage. I punched a hole in the already drywalled exterior wall today to find that there is no insulation in it. I haven't been in the attic yet to know if it is void of insulation, I'm probably doing that tomorrow, but that is the lesser concern, as I'm sure all options are available for insulating the attic space. Some of that space is under the master bedroom, and some is open to the attic space.
My big question is what options do I have for insulating the walls? After drywalling my entire basement in my old house I promised myself I would never do drywall again, so if I have to take the drywall off I'm paying someone to put it back. I've read I can get spray foam done by using the expanding foam, so is that the best option? I assume the other option is blown in insulation, both of which require holes in the wall. Is spray foam better even when installed in an existing wall? Will taking the drywall down be more than marginally better in r-value, assuming I use a competent installer?
Thanks in advance.
Other notes, I will be heating with a forced air type natural gas heater and will be running wiring which I'm happy to have as exposed runs of conduit. Same for the gas lines, I don't feel they need to be covered by drywall. This is a garage after all. Budget isn't unlimited, but I have the funds to "do it right" lets say. In other words i don't need to cut corners to save $ if there is long term savings in doing it right, but I don't want to incur the cost of drywall replacement if all i get is a pretty wall. Also I considered the idea of plywood for walls, but my wife balked at that idea for some unknown reason that I'm not interested in debating.
Thanks in advance.
