another GCFI question
diesel06
pennsylvania
i have detached 42 by 27 mortan building, concrete floor, are gcfi outlets required or can i use regular outlets
engineer2
Chicago burbs
Depends on local code, but required near wet areas like sinks and bathrooms.
115VAC 20 amp circuits with 12 gauge wire is the norm for industrial buildings and residential bathroom outlets around here, GFCI for the bathroom, but not for regular outlets..
D
diesel06
pennsylvania
no bathroom in the garage, ill have a small sink in the corner but thats it. pennsylvania is the location
Stuart in MN
Minneapolis
Pennsylvania uses the 2008 edition of the national electric code (NEC.) Per NEC article 210.8(A)(2), 120vac 15 amp or 20 amp receptacles in a residential garage or accessory building need to have ground fault protection.
toyotadriver
You should do what your area requires. Since my area doesn't require them, I just put in regular outlets in my shop building.
Shiftless
East Bay SFO
Did you ever get a shock from a faulty electrical part? Did anybody you know ever touch a worn extension cord and get shocked? I do. He couldn't let go of the cord because his hand muscles locked up. If the neighbor wasn't nearby to yank the cord from the outlet, he would now be dead.
How much money will you save by omitting one or two GFCI outlets? Twenty bucks? Think about it.....
tfi racing
Cedar,BC
Yeah,maybe.Now please tell us how an AFCI saved your puppy's life at the orphanage and we can all shed a tear together...:rolleyes:
Norcal
GFCI's do work well and are not expensive, if a residential outbuilding they are required, non dwelling garages, service bays, and similar areas do require them per 210.8(B)(8).
D
diesel06
pennsylvania
the building is just a work shop, no living quarters or anything like that, i guess it would be classified as residential, its not a new build, it was built in the 70s not being inspected just updated the wiring and i want to do it the right way and i priced gfci, they are pricey compared to regular outlets. would all the outlets have to be gfcis? im running two circuits for outlets, 6 on one 6 on the other
FordTruckWench
California
You might only need two GFCI receptacles. Install them as the first device on each circuit. This way they'll protect all downstream receptacles.
Or you could install two GFCI breakers.
Shiftless
East Bay SFO
Just put a GFCI receptacle first in line on each of your two circuits. Use regular receptacles on the rest of your receptacles on that circuit. Follow the directions included in the box. You will only have to buy 2 GFCI's.
D
diesel06
pennsylvania
ok cool, ill just do it this way,that will save me in having to buy 12 gfci outlets
toyotadriver
None of those horrors have ever happened to me or anyone I know.
I only have GFCIs in exterior outlets and kitchens and bathrooms. Everything else is regular outlets. I sleep well at night.
Shiftless
East Bay SFO
The guy I mentioned was using an electric weed eater, standing on wet grass, with a bad extension cord...(torn insulation exposing a conductor) plugged into an outdoor receptacle NOT protected by GFCI. Yeah, he was stupid for not replacing or repairing the cord but maybe the death penalty is too harsh for stupidity.
Right after I heard his story, I upgraded all my outdoor receptacles (on my 64 year old house) to GFCI even though I toss damaged extension cords.
rsnip988
Elon NC
That's what I did, but I have 35 outlets on 7 breakers so it would have cost me considerably more to go all GFCI outlets or breakers!
