aunsafe2015
I read through the other generator thread and have some questions for the collective wisdom of the forum.
1) Can somebody briefly explain a "Service Disconnect" vs a "Load Center" style transfer switch? I see some that are referred to as "Service Disconnect" switches, such as this one: https://www.electricgeneratorsdirect.com/Kohler-RDT-CFNC-200ASE/p2207.html. The other main type I see are apparently called "Load Center" transfer switches, like this one: https://www.electricgeneratorsdirect.com/Generac-RXG16EZA3/p77439.html.
Am I correct that the "service disconnect" style connects to your main breaker and would be easier to wire because you do not have to wire each individual circuit? And it provides power to every circuit in your main breaker box? And that with the "load center" style, you select some number of circuits from your main breaker and the "load center" disconnect switch is almost like a subpanel?
With a "service disconnect" style breaker, what happens if you try to use more power than the generator can provide? Your entire house shuts off?
2) Apparently Generac makes "portable" style gas powered generators up to 17.5 kW: https://www.electricgeneratorsdirect.com/Generac-5735-Portable-Generator/p2685.html?akamaifeo=off. The main alternative I'm considering is a natural gas standby type such as https://www.electricgeneratorsdirect.com/Kohler-14RESA-Standby-Generator/p8198.html.
The portable type would presumably be cheaper b/c all I'd have to do is get a transfer switch wired up. The standby type would require a new gas line and probably a meter upgrade to handle the extra BTU requirements, as well as clearing a space, creating a pad, etc. I suppose the benefit of the standby is that it would automatically switch over, I would never have to refuel it to maintain power. I guess it would probably also be quieter.
In terms of the "quality" of the power generated by each, is "total harmonic distortion" (THD) the relevant measure? I saw one review claiming the Generac portable is <5% THD, which is the same as most of the whole-home standby styles. Does that mean the Generac portable would provide the same quality power as the standby types? And at < 5% THD would be safe for things like TVs, computers, etc?
Thanks in advance for any input.
