mybigchevy
Over the weekend I layed down Coronados 100% epoxy over my 545 square foot garage. First off Thanks to all that post great write ups and give out great advice, Thank You I could not have done it with out you guys. I started out by cleaning the floor with Simple Green then rinsed and rinsed. I then etched with 2 gallons of acid mixied into 2 gallons of water and rinsed and rinsed with the preasure washer. When the floor dry the next day I layed down 6 gallons of grey Coronados 100% epoxy using a notched squeege that i was told would spread the epoxy at 15-20 mils, then I backrolled with a 18inch 3/4 nap roller and finally I broadcast 30 pounds of 1/4 inch chips into the floor. The next day I layed 5 gallons of Coronados clear epoxy On top using the same application method. All I can say is wow The floor looks great it is super dense and still looks wet but its dry enough to walk on nowThe Coronado product is easy to use and mixing it up is simple no measuring to do, just dump the activator into the epoxy pail anf mix. Hear is a few shots during and after the clear is on and dry.
