bens
Last night I could see my breath in my cold barn. So it's time for some insulation. I have a 42'x75' Morton builsing. The columns are 7' 6" OC. Walls are 10' and 15' high. Soffit and Ridge vents.
During the winter I get out to the barn a couple times a week or more and would like to be able to warm it up to a tolerable temp. And if I could keep it above freezing at all times, that would be great. I'm thinking of going with a furnace with basic duct work through the barn.
Here are my guidelines (some of which my be unreasonable):
1- no drywall, i like the "barn" feel that it has now and will cover the insulation with wood of some sort. Would love to find some old barn wood and use that.
2- no ceiling, I like the open trusses. I realize there is a loss of heat up there, but I use it for storage and it makes the barn feel bigger.
Questions:
1- What type of insulation will be cheapest and still effective
2- Any suggestions for insulating and sealing a 14' x 14' sliding door?
3- Can I insulate the underside of the roof and not put in a ceiling? If so how does this effect the soffit/ridge venting?
4- Any reason not to use a standard furnace or should I go with a few Hot Dawg type units?
I'm open to any other suggestions and criticisms. Here are a few pictures to give you guys an idea what I'm working with.
Thanks in advance.
Questions:
Thanks in advance.
