FreezingBarn
- Joined
- Dec 7, 2021
- Messages
- 2
Lurker here, but it's that time of year, yes, another help me heat my pole barn thread. Here's what I've got:
Here's what I've ruled out:
- 48X32 pole shed with 11' side walls
- R19 Silvercote insulation installed on the side walls
- This is in Minnesota... it gets COLD.
- There will be no ceiling attached to the bottom of the trusses, the trusses will remain exposed (i.e. no blown in insulation)
- No additional framed walls, the shop will remain wide open like in the picture
- Shop will remain unfinished
- Trying to keep it relatively aesthetically pleasing...
- The slab is done, there will be no in floor heating.
- Spray in insulation wouldn't be doable until the spring, is too expensive, and I've heard it can warp the metal roofing, I'm ruling this out.
- Insulate the ceiling with R30 silvercote faced blankets between the purlins (similar to the side wall).
- I'm thinking about just completely sealing/filling in the ridge vent and cupola (that's the light in the middle). Thoughts?
- I'm also thinking about adding some rigid foam board with foamed edges before adding the blankets, maybe R5-R10 boards plus R30 seems like a good number. Thoughts?
- I may need to add some more beef to the sides, but not 100% sure.
- There are some vents/seals on doors/garage door/etc. that I'll have to seal up.
- If I do all that, is there a heating solution available that will suit my needs? Would it be possible to heat this thing to ~50 degrees if it's 0 outside? Options:
- Infrared electric
- LP furnace
- Combo heat pump and propane torches?
- Nuclear reactor
- Will this insulation approach work?
- What heating option should I go with based on all the other requirements?
