Another HF 72" based Workbench
IMSA GTO
Loudoun Co Virginia
Long time lurker and admirer of the many interesting HF, Menards, Craftsman, etc toolbox workbenches on this forum. Like many here, I am stuck in the typical suburban 2 car garage without the space to build the larger frame multi box type set up that I could really use to organize my small shop.
Existing tools and equipment left me with about 78" of wall space, and my initial stab at organization after moving in was a set of MDF Coleman cabinet bases with drawers. Once loaded with tools, parts, and hardware the shortcomings of these cabinets became very clear. I needed a solution that would increase the storage density (mostly for specialty tools, hardware, and supplies), but be cost effective and provide a solid base for a workbench surface.
Unfortunately, I don't live near a Menards to be able to take advantage of their 72" box which I preferred, and shipping costs for theirs and any other heavy duty boxes pushed the limits of the budget too far (not lucky enough to find a good deal on a used Snap On on CL either, but I am sure one will pop up now that I have pulled the trigger on this set up!) I have to say though that the HF box is pretty nice for the price, and a few of the drawers I have loaded with heavy fabrication tools seem to open and close better than when unloaded.
I wanted to get the cabinet as low as possible to obtain a good working height for the top surface, and since I am only using the one box I decided to fab up some simple plates and feet to mount in place of the huge casters that come with the box.
Leveler feet came from source on Amazon, about $7.25 each. Steel tubing and plate were from my scrap bin.
I didn't have plate as wide as the caster plates that came off, so could not pick up the second set of bolt locations, but after seeing how heavy the support frame is and the fact that my legs are simply in compression only I went with 3" wide plate and two bolts. I'm not moving this thing, particularly after loading it, so it won't be an issue. This thing ended up solid as a rock.
I went with a 1.5" Oak butcher block top from Lumber Liquidators since I have one close by. I would have preferred a stainless top, but I wanted to fill up the 78" available space, and cost to have a custom stainless one fabbed up was more than I wanted to spend on this now. Top is one of their builders grade 8' x 25" that I cut down and rounded over the top edge. I also wanted to keep the overall height as low as possible, so I routed out relief grooves on the underside so that the top would sit flush on the top of the HF box with overhang on each side and about 2.5" in the front. Final height after leveling is 40.38".
Seems solid as a rock so far. Will update down the road.
ssdave
Eastern Oregon
Trying to add images for you:
http://i.imgur.com/9KrqRFb.jpg?1
stage20
pcola FL
id have never thought of lumber liquidators for a top. how much did it run you? ive been wanting to do one for my box. right now i just have a cheap butcher block look counter top i scored off craigslist
LXCam
The pics are working for me and so is the bench. Nice job.
avayan
Melissa, TX
You know, I come here to learn about garage's and workshops and little did I suspect I was ever going to pick up stuff on other areas, such as workbenches. That little tidbit on the butchers block at Lumber Liquidators will come in handy like heck! Thanks for the details!
larry4406
Northern Virginia
Very nice bench and top! I too would not have thought to get a butcher block top from lumber liquidators.
What is the overall width, depth, and height of the box with the casters still on?
188slo50
Virginia
Very nice!! Have any more pics of the feet you fabbed and what you used? Check Craig's list for the stainless tops, I noticed a lot of places selling off industrial kitchens when they close down.
I
IMSA GTO
Loudoun Co Virginia
Thanks guys, appreciate the comments. We'll see how this box holds up down the road.
1.5" x 25" x 8' in builders grade oak lists for $180. They have Hevea for the same price, but it is quite a bit softer. Hard maple in same size goes for $270 which would have been nice, but at that price I probably would have spent a few more dollars and gotten a SS top fabbed up.
The box itself without handles is approx. 71.5" x 22.38" x 44.25" (with casters). The feet that I welded up lowered the working surface of the box to about 38.88", and I routed slots in the bottom side of the oak top so that it would sit flush on the box top work surface and not on the raised perimeter lip/edge sheet metal. Ended up lowering entire assembly about 4" which makes a nice counter height working level.
I found these machinery feet on Amazon for $7.50 back in early Dec. When I just went to grab an image for you I noticed that price has now gone up to $11.49 ea. Gotta love Amazon. I agree with you on CL scores from time to time. I had a limited amount of time off over the holidays, and wanted to get this project completed so went the butcher block route. Wife is already eyeing the remaining drop piece of butcher block (about 18") and suggesting that I consider a small kitchen project out of it. :thumbup:
manwithtools
Lebanon, TN
Excellent job and nice recommendation on the LL butcher block. I had no idea they even offered that. Has given me some things to ponder.
