marknbacon
- Joined
- Sep 4, 2026
- Messages
- 2
Yep, another hydra-lift thread.
Although it looks like most of the threads on it are pretty ancient.
I recently acquired this used, ancient lift off marketplace for a whopping $300. I'll need to replace some parts as some are completely missing or not going to work for it (power unit the guy gave me isn't going to work for this thing...)
I don't need help IDing it. Panzitta sales and service in PA responded to my e-mail with a manual that matches it perfectly. It is an old model 27ACF.
I'm fabricating my own upper pulley pins as I think that paying ~$230 EACH is outrageous. The safeties on each arm are the problem now. Again with the $200+ parts, and I need 4 of each.
My main question is this: It doesn't have external teeth on the back side of each arm, so it uses an entirely different safety mechanism. AI thinks it uses a plunge-block style latch since the manual has the release pin below the bottom edge of the arm mounting plate, but I honestly don't see any real evidence of it. Anyone know more about these old things? I would like to get this thing up and usable in the next month or so as I need to replace the clutch and pilot bearing on my car.... I guess 700+ hp and twin disk clutch was too much for the OEM pilot bearing (Yes, yes, I replaced it when I put in the twin disk. Apparently the OEM one isn't very tolerant of the extra heat the twin disks generate)
