89efhatch
I know this topic has been covered quite a bit but wanted to lay out my situation and see what you all think.
I have a 30x38x12 pole barn with scissor trusses. I have insulated all the walls with R19 fiberglass batts. I have done about 1/3 of the ceiling with R19 batts and noticed that the metal roof deck sweats on occasion. The ceiling insulation is on the lower part of the trusses not touching the metal. I have a 36k btu mini split that I will be installing when the insulation is done. I plan on keeping the shop around 50 degrees and warmer on weekends.
Once the ceiling is done will the sweating above it stop?
Should the insulation be touching the metal?
Any thoughts would be appreciated
Thanks
Mike
Thanks
Mike
