Another insulation question doubling up?
Soccer918843
Upstate ny
So I have a 30x52 new build garage I plan on using rock wool r23 in walls and rock wool r30 in ceiling would 1.5” foam insulation be worth it on the exterior for the added cost? Will it pay for itself with the heat savings?
68sixspeed
CT
The payback could take a while, I have a 30x50 with 13ft ceilings, same insulation specs, I keep it 58 degrees all winter and then bump it up if I'm going to be out there working, I burn less than 200 gal of propane a winter to heat it with a hanging modine heater. Usually 125-150 gal is a normal winter, 200 on a bad winter or if I'm working out there a lot. One thing I think helps is I'm not putting a cold truck in/out everyday, this is a detached garage more for projects not daily driver use.
I'd recommend investing in the best overhead doors you can afford and put the money there and sealing around them as well as a quality window and sealing those as best you can. I figued R30+ walls are not going to be that big a help with two 10x10 overhead doors with R16-R18 max.
u2slow
BC
IMHO, not worth it. Insulate the ceiling better.
Board insulation is spendy for its R value. I'm using it under siding because my existing walls are no better than R10-14 or so.
tonyciambrone
Northern Illinois
Agreed here- R-23 in the walls is good. r30 in the ceiling is not ideal. For Upstate NY i think you would be looking at R-49 to meet most codes/ recommendations
Soccer918843
Upstate ny
How would I achieve r 49? I have attic truss and only have 7.5” to insulate the height of the bottom of the truss and floor will be on the ceiling in the garage and another floor in the attic.
Bert_
NW Iowa
Bigger thing is to air seal. All the r-value in the world doesn't mean squat if air can blow through it.
If you tape all the seams of the foam board that would air seal. But it's far from the only way.
Soccer918843
Upstate ny
Ik spray foam is the best way but I can’t pony up the 7k to insulate if it was a house I would but a detached garage I can’t get myself to spend that kind of money
Yes, it will pay for itself. The question is how many years !!
Starting with R30, I don't think it is worth the cost.
toyotadriver
YES to rigid foam sheets on the exterior. Upgraded insulation pays off. Rigid foam on the exterior does something batt and even spray foam can't do...it slows the heat gain/loss from the thermal bridging of the studs.
I built a house with metal siding and before we put the metal on, I had 1 inch foam sheets put over the exterior. Payback time was about 3 years or a little less. We plan to live here for a long time. Our utility bills are very low and will remain low.
jabin
SW Ohio
Like putting a coat on to cover everything vs sticking insulation between your ribs. But it would also pay a lot to put a hat on since a lot of heat loss is via the roof.
tonyciambrone
Northern Illinois
Ok so more information is probably needed about the construction and layout...What is the truss construction like? What is the spacing? Is the roof just steel over purlins, or is it sheathed? Are you venting the 'attic' or sealing and conditioning it? etc
