Okay guys I am reaching out for your wisdom here.
I have several jobs in the last few years where I needed parts that are either very $$$$ or unobtainable.
For one job I needed a splined shaft, I finally found one and the asking price was $525.00, a local machine shop quoted me $395 to make one. In the end I welded the old shaft back together and it is still working but it took me about 4 hours to weld and straighten it.
I have been searching for a good mill and lathe in a 200 mile radius for a couple of years and have yet to find one that either is made of gold or not so clapped out that it isn't worth my time.
Today I went and looked at a lathe that had all the features that I am looking for, ie quick change gear box, quick change tool post, tail stock, steady rest.
The ways had a lot of wear in the sweet spot .014 over about 18 inches, the cross slide had .006 of back lash and the travel had .009 of back lash. and he wanted $2200 for it.
I have had the same kind of luck with mills.
So I have 2 questions.
Which one would you buy first Mill or Lathe?
and second, would you keep looking for a good used machine or bite the bullet and buy a offshore machine like one form KBC or Grizzly?
I can see some of the benefits from buying a new machine 1ph motor and controls, parts availability, no more searching auction and CL listings.
Here are 2 of the mills new I have been looking at.
http://www.kbctools.com/products/MACHINERY/MILLING%20MACHINES/MANUAL%20MILLING%20MACHINES%20WITH%20DRO/10147.aspx
http://www.grizzly.com/products/9-X-49-Vertical-Mill-with-Power-Feed-and-DRO/G0796?utm_campaign=zPage
