I recently purchased a Millermatic 211 and wanted to use the basic harbor freight cart that I had purchased a while ago. The welder itself fits perfectly on the top shelf of the cart; however, there are some problems.
The main problem with the Harbor Freight cart is that the top shelf of the cart is tilted, which causes the welder to interfere with the gas bottle.
The other problem is that the lip on the top shelf prevents the side door of the welder from being opened.
I address both of these issues as well as upgraded the bottle mounting mechanism that comes with the cart.
I put the cart together per the instructions and left the to top shelf off. Since I want to mount the top shelf horizontal I will need to drill new holes in the uprights.
Next I need to straight the back lip of the shelf. The back lip is bent more than 90° to accommodate the tilt. I used my vise for this.
I used my cutoff wheel to cut off the excess length of the uprights and filed smooth.
A little paint to touch up.
I also drilled new holes for the wire holder to mount it lower; thus, not to interfere witht he welder's side door.
