windswept4
Hiball did such a good job on his tutorial called the Overseas Jack Rebuild Tutorial, I'm hoping someone can address my jack specific question:
I acquired a floor jack with no identification other than it is painted red and claims to be a "BlackHawk" with an 1,875 Kg capacity # GG920904416. A national service shop rep says that's not a valid domestic BlackHawk id number so I figure it's an oriental counterfeit.
During disassembly all the BB's (check valves) and needle valve and spring gushed out with the jack oil so i dont know which item goes into which drilling hole. The 2 small BB's (check valves) measure .025 inch in diameter and the large BB (check valve) .035 inch diameter. The 4th check valve "BB" is inside the release valve hole and I know this check valve is properly located because it never fell out of its cylinder and is still in there.
I have guessed at the location of the parts and have laid them out in a line with each drilled cylinder (see photos so see how I have laid them out); but this is only a guess! Can one of you take a look at the photos and tell me which parts should go into which cylinder and in what order?
Once I get some help on this, I'll rearrange the exploded view of the parts in to show them in the proper location; then I'll take a new pic and post the proper order.
Many thanks in advance to Hiball and any of you for sharing your experience with me on this.
I hope the links to "photobucket" work ok. If you can't pull up the pics, let me know and I'll try posting again.
http://i1104.photobucket.com/albums/h336/windswept4/Hydraulic Floor Jack/IMG_0450.jpg
http://i1104.photobucket.com/albums/h336/windswept4/Hydraulic Floor Jack/IMG_0451.jpg
http://i1104.photobucket.com/albums/h336/windswept4/Hydraulic Floor Jack/IMG_0535.jpg
http://i1104.photobucket.com/albums/h336/windswept4/Hydraulic Floor Jack/IMG_0534.jpg
http://i1104.photobucket.com/albums/h336/windswept4/Hydraulic Floor Jack/IMG_0529.jpg
