Hey all,
Great resource here! Here's what I've done so far:
1. New construction, couple months old, unused, in Colorado (dry)
2. Rented an orbital sander and went over it with 80 grit (use to sheets at a time to keep from ripping!)
3. Use H&C etcher a couple times. First half strength, second full strength.
4. Rinsed 3 or 4 times, once with a little baking soda in it to neutralize acid.
The problem is that after I added the acid, the floor had a "whiter" color... moreso in some spots than others. Also, only some spots had a sandpaper-like roughness, while others (especially where it is whiter) are smoother to the touch.
I worry that I didn't rinse the acid off soon enough (dried very quickly here in the low humidity) and the results of the etching are trapped still and it won't make a good bond.
Can anyone comment with knowledge or experience?
(This is not the white stuff from moisture in the concrete... it's not crystaline).
Thanks!
By the way, once the floor is prepped, I'm going to use AmourSeal 1000 HS and some chips (vinyl?).
Thanks,
Mark.
Thanks!
Thanks,
Mark.
