Another rack for Harbor freight organizers
dmcgrath009
Rochester NY
Long time lurker of the forums here I recently moved into a new house and started building out my basement shop.
Been working on a few projects down there and will likely put up a thread about the entire project but for now I wanted to share my approach to a storage rack for the harbor freight organizer bins.
The rack itself is built from 3/4" ply and the runners for each bin are 1/2" ply
The unique part of this approach I havent seen anyone else take is how I modified the cases. You can see in some of the photos below I removed a portion of molded case at the back edge so that most of the top edge if the case sits nicely on the 1/2" pllywood runner. The matching front molded corner I left in place and it acts as a stop for the cases as you slide them in.
Here is a video explaining the case modification
D
dmcgrath009
Rochester NY
The rack was built as part of my work bench, the outside frame is built for 4'x4' and the top is a piece of Quartz I picked up from the remnant yard at the local countertop dealer. The bottom has 8 adjustable leveling casters so the bench can be moved if needed.
D
dmcgrath009
Rochester NY
Rayra,
Here are the casters I went with, they have a hard rubber foot that can be raised and lowered with a built in ratcheting mechanism.
Short video of them in action - https://photos.app.goo.gl/CtYXtS9tNaFM1W3KA
The reason I went with these casters is becasue the bench will be primarily stationary but there will be some projects where I may need to move it out of the way. I also wanted to be able to level the bench.
Jayman17
Seattle, Wa
I like the rack and judging from the bits I can see in the background of your photos, It looks you have a really nice shop too. :beer:
Jay
D
dmcgrath009
Rochester NY
Jay
Thank you for the kind words Jay!
I will make a whole shop thread soon, just figured this deserved its own thread as I think its a fairly common issue people are trying to tackle.
y'sguy
Tulsa, Oklahoma
I really like what you have done especially the casters.
Do others ever use these parts holders in a vertical storage position, "book-style"? I think I would prefer it but realized it may not work as the contents might fall out of the separate compartments. Just a thought on a project I may attempt.
D
dmcgrath009
Rochester NY
Thank you y'sguy!
I have not seen anyone go with the "Book-style" configuration for these organizers reason being exactly what you outlined, you would be more likely to have parts move from bin to bin internally. I think it would really depend on what you are storing.
D
dmcgrath009
Rochester NY
Great work there. Love the rabbet joints for the 4x4's.
Did you screw and glue any of the construction in general, or just screw?
Meursault,
Thank you, I was going to glue it together but found the screws were sufficient. Also if I ever need to take it out of the basement it will be a lot easier this way.
I like it. How long did it take you to design it after your initial thoughts?
Captain14,
I picked out the top for the bench first, the lead time to have it cut to size and finished was a few weeks so I had time to think about how I wanted to build this. I laid out the height of the bench and the number of storage bins I could get under it, considering the frame and built from the inside out. The rack system was built and then the 4x4 frame around it to fit. I work best on the fly and was better off in the situation building in stages.
rayra
Escaped from Los Angeles
Rayra,
Thx, much appreciated. I have a 3-car attached suburban garage with the single stall as my workshop. I've put most of the shelves, workstands and a large 4x8 table all on wheels. I can expand or contract the space as needed for projects. I'd particularly like to put these or something like them on the big rolling work table.
Onebean
Nebraska
Very nice work on the HF organizers rack. I like those casters too (already have a set in my Amazon cart). I‘m envious of your organization, very nice work overall. It’s threads like this that inspire me and raise the bar. I can’t wait to see the full thread on your workspace. Till then, take care.
D
dmcgrath009
Rochester NY
Bit of an update, I liked my basement storage racks so much that I opted to incorporate another set into my new garage bench. Here is how it turned out!
Jim_No_Garage
Millington NJ
Wow - that looks really nice! So how do these cases hold up if they are heavily loaded (ie with lots of small screws or washers) since you are only supporting them at the edges? Other examples of such cabinets had individual shelves that the cases rest on to support the weight.
Cheers
Jim
D
dmcgrath009
Rochester NY
Jim,
They hold up pretty well actually, some of the heavier cases have a ting bit if sag in them but completely usable and haven't caused any issues yet.
This case is pretty heavy filled with M6 hardware and it's been stored in the basement racking for over a year.
mazdarick
Do you happen to have dimensional drawings for your cases! I'd like to build this in my super unorganized garage and you rack looks really nice!
bazzz
Heathsville Virginia
I like the idea of rails for the boxes to hang on instead of making a plywood shelf for it to sit on like I did. This would have saved me some material and probably a lot of time. Here’s a picture of my version of the storage I created under my bench.
