Stucco
Hi, my new-to-me garage is leaning a bit, and I assume it's better to fix this sooner than later.
You'll see that it's moved only slightly, but I think it's still moving and I want to stop any progress.
If I get it back to square before bracing, I'd like to start by "pushing" it back (as opposed to using come-alongs). The pushing method was briefly described here as:
So for now the questions might be:
1. Can anybody dumb-down the "pushing" method described above? I'm not sure I understand how the bowing and staking works.
2. Stupid question, do I really need to square it up first, or could I just add lots of bracing and call it good?
Thank you for any ideas!
The corner of the garage attaches to the house:
View media item 53483
Opposite side of the crack above:
View media item 53487
The far end of the garage (the "leaning-towards" or downhill side):
View media item 53486
Opposite view of the corner above:
View media item 53490
And finally, the other corner on the downhill side:
View media item 53489Some guys doing some work on the floor (which was all busted up) had extra Quikrete and wanted to help patch things up... Also it looks like somebody had patched this before the last time it was painted maybe?
He suggested just putting some long 2x4s up against the side, leaning on em to bow em towards the ground a little and putting a stake in the ground to put some pressure on the side to help it along. I did that and it moved another half inch. He told me the longer 2x4s the better - more bow.
I can't help but thanks for the laugh.
