slackdaddy1
I have a 12'x10' Shed 6' from the side wall of the detached shop. The electric meter for the shop along with the shop's 200A panel (inside) are on this wall about 9' from the corner of the shed. The shop has it's own 200A service and ground rods in no way associated with the house.
I am moving my compressor to the shed (80 gallon, 5 HP (230v on 30A breaker now) and would like 1 or maybe 2 115v circuits in the shed.
A sub panel in the shed seems like the obvious choice ?? Burying PVC conduit 18" deep from the shed and an LB body into the back of the panel and pulling 15' of THNN would be easy.
(rural area, there will not be permit/inspection)
Questions
Do I have to drive separate ground rods for the shed,, or can I hook onto the garage ground rods that are 9' away from the shed??
Unbond the neutral bar in the sub panel,,
Or should I just run a 230 circuit and a 115 circuit from the shop panel and forgo a sub panel?
I DO plan on adding a wall switch in the garage and a contactor for remote on/off of the compressor,, HMM.
So with the remote on/off of the compressor in mind,, suggestions on what path I should take.
Questions
