exranger06
I feel like this question has been asked a million times before, and I feel kind of dumb for asking, but I'm getting a little overwhelmed reading through dozens of threads, some with conflicting information, and getting confused.
So, I'm trying to decide which type of wire to use to feed my subpanel. Subpanel is in attached garage, I ran 1.5" PVC conduit from main panel to subpanel. Part of the conduit run is underground, not sure if that matters. Total conduit run is less than 20 feet. Subpanel is a 100A panel and I already have a 90A breaker to go in the main panel.
I know I can use 2-2-2-4 MHF, but was wondering if there are any better choices, maybe something that would be easier to pull through the conduit. #3 Cu THWN? If I went with THWN, which size ground should I use? Cost isn't much of an issue, since I only need about 20 feet of it. Just wanted to know what would be easiest to install and be code compliant.
