Another tool whatzit...
chrismenke
Sam's Clam Disco, CA
No idea what this is...40lbs of K.O Lee Knockout machinst's something or other...anyone?
Carla
MEMBER EMERITUS
hmmm..........early style hard seat set for automotive valve work?
The cutters would cut a counter-bore in the block, a press or drive fit for the hard seat ring, which would then be ground for a correct valve seating. This would be used if the original seats were 'sunk' from being ground/lapped too many times, or in conjunction with a line of taper pins, to repair a block which had developed a crack at a valve seat.
A bit of history.....from the 'flathead era'.......... : )
cheers
Carla
Josey Wales
Tacoma, Wa
A quick search....
Profile: K.O.Lee Co. produces industrial grinders and supplies line of surface, cylindrical & tool and cutter grinders. Our products include tool grinders, tool grinder fixtures and accessories, expanding mandrels, keyless drill chucks, valve refacers, valve seat grinders, valve seat insert rings, reseater sets, rod aligners, stud wrenches, sanders, AC welders, drills, polishers & reaming drives. Our small tools include abrasive wheel dressers, bench centers & surface plates and expanding mandrels.
