Another "what is it?" - Strange jack
D.F.
Hi all,
I'm in the process of pulling some old jacks from my house. I have a strange small 2 prong jack that I need help identifying. I'm pretty sure it's an old phone jack or possibly for an antenna but figured I'd check with you guys.
I tried finding the other end of the cable but it is buried behind a duct.
The two outer holes are screw holes. The center ones are the plug. It's connected to a black, 2-conductor ribbon cable.
I get no voltage from the cable on the multimeter.
Thoughts?
Thanks
-A
laser3kw
northen IL
300 ohm flat antenna lead.
if you need to use it, you will need a balun to convert to 50 ohm coax that most tvs use .
joe_padavano
Northern VA
Wow, I haven't seen one of those in decades! Here's what the mating plug looks like.
