Another "what the heck is this" find
Ed in Virginia
Montpelier, VA
I received this in a box 'o tools from an estate sale. Looks like it may have been used in a jack hammer or something similar??? I have never seen anything like it and would love to find out more about it. Thank you in advance!
IndyGarage
Indy
Could it be some sort of adapter from taper square drive to round taper drive? Typically a taper has slots in it like that so you can use a wedge to pound out the bit.
I cant see inside the hole on the round end to see if it is tapered.
dscheidt
Man can you imagine cutting tenors with a hand brace drill? Men were men back then..lol
Tenons? For a chair or something? I've done it, and probaby will again, with a tapered cutter. (and drill the matching holes with a tapered bit, also in a brace). It's not that hard, assuming your cutter is good and sharp, and you've preshaped the tenon with a plane so the amount of material that has to be removed is small. Is it more work than some power tool? Sure. Is it less skilled to use the power tool? Yes, that too. But this is not really the sort of thing that you would be thinking "geez, there should be a machine to do this" the way a long saw cut or flattening a board with planes gets you thinking.
Old Man Roger
Palm Coast Florida
Might actually be a brace driven Die Holder. The threads on the low end secure the die.
Kinda like this
Or this
I think you’re on to something. I didn’t see a place for a blade if it were a tenon cutter, but the picture was dark.
Ya, I’m lazy. Lol
