Another "which welder" thread
JoeOef
MN
I've been shopping for a welder for some time now, and now that I'm about to pull the trigger, I've got salesmen pulling me every which way. I had originally been about to pull the trigger on a Hobart 210MVP, and an Everlast Powerarc 140 tig/stick. Then I thought I was talked into buying a Miller 211 and skipping the tig option for now.
After a bad experience at the local Airgas, I went to another local welding shop where I am looking at a Thermal Arc 211i with 80ft tank, cart, 33lb spool and a tig torch out the door for $1600 with a free welding mask. The 211i seems like a fantasic piece of kit. LWS is throwing in first fill with the tank (purchase, not lease) and I could likely get them to throw in a welding seminar.
I've welded for a total of perhaps 4 hours in my life. It's a skill I am serious about adding to my toolbox, and I want to spend once. Dual voltage is important to me, having the ability to learn mig/tig/stick is important to me, and quality and customer care are important to me. COO is important, but less so. Thoughts?
zkling
If you really want to do mig and stick/tig to their fullest capabilities you will need two separate machines. The TA211 is nice, but it is a DC only machine. You will not be able to tig weld thin aluminum with it which requires AC output.
I noticed that price is not important to you? What is your total budget? What type of projects do you plan on welding? Please be specific.
J
JoeOef
MN
The TA package runs $1600 OTD which is the most I absolutely want to spend for machine, cart, gas etc.
Welding a lot of scrap for practice, trailer repair, motorcycle parts eventually, patch panels on older vehicles, general hobbyist stuff.
zkling
In that case, I would forget the tig for now. Agree that the 211+spool gun would be a great fit for you.
J
JoeOef
MN
Well guys, my wife bought me the Thermal Arc PowerArc dc tig and stuck set-up for my birthday and I just got back from the Shop picking up my Miller 211 with tank and spool gun. No buyers remorse yet.
FriendOfYours
Take them back and get the 211i!
It is an excellent machine and will do way more than what you now have, for cheaper
Your Miller 211 is really only 150a at 30% duty cycle
The TA on the other hand will actually do 210a at 20%
I have both btw. The 211i hits the cutoff at max a couple minutes after the 211 and penetrates deeper
J
JoeOef
MN
Dang where were you three days ago?
The salesmen said the same thing, only that the miller was more reliable.
stonewellmark
Hudson Valley, N.Y.
Congrats on your mm211!! I just got a TA 211i....gotta tell ya it welds super smooth, with plenty of heat ( at least MIG ). Fan is a bit loud, and it is by no means a realistic "portable" machine especially with a 33+ pounds spool o' wire in it. Best of luck with your new welders!!
Mark
Tunajoe
Ventura County
Following this thread closely as I'm in the market for a beginners welder.
The miller 211 seems to be the ticket for me.
What is the advantage of the spool gun?
Rezarf
Spool gun makes aluminum welding possible.
theknurl
SoCal
so you mean all those 10 lb boxes of aluminum rod I've used and have still, went to waste......
because I don't have a spool gun????
really?:lol_hitti
sure welded a lot of aluminum without a bulky spool gun
pipsters
USA
really?:lol_hitti
A stick welder is different than a MIG welder. With a MIG welder you use a wire fed from the box to the gun. Typically the wire for aluminum is too soft to feed through the gun so you have to feed it out at the source, hence the spool gun.
Mitchw123456
kemah tx
I chose the 210 mvp after a long debate between it and the 211. I wasnt a fan of all the autoset and extra stuff to break on the 211 and stumbled across a sale at blains farm and fleet for $900 with spool gun shipped to my door.. Couldbn't turn it down and couldnt be happier
#1SomeGuy
Canada
Auto-set is optional, you don't have to use it. The biggest benefit of the 211 is continuously variable voltage rather than stepped.
zkling
Yes, but in industrial settings and even some home shops spool guns are not as economical (small spools of wire) or nimble as a standard mig gun. Thus there exist push pull systems (constant wire tension) to feed full size spools of mig wire through a standard length mig gun. Can you do it without push pull system? Sure, but when you combine a small all in one unit, low amperage thus running small wire--> lower column strength + tights bends + trying to run from a small spool (small initial bend radius) and a steel liner like most try. Then the results are usually not going to be fun.
I like the 210 and one of the reasons is tapped voltage. So easy to set and repeat
:+1:
pipsters
USA
:+1:
Yes, because clearly this guy is going to be using this new welder in an industrial setting. :dunno:
theknurl
SoCal
really?:lol_hitti
pipsters;
I use 36" rod with a Lincoln 300/300, bet I haven't stick welded anything in 25 years
now, I've used stick rod with the coating cleaned off for hard facing etc, with TIG
cleaning the coating off is less trouble than changing the cables
and I have a 200 amp MIG machine with, what are they 33lb rolls?
been welding for 58 years
:beer:
