DavidB
I picked up another vise at the flea market and am in the process of cleaning it up. It's a Wilton No. 4, with 4" wide jaws, and weighs about 32 lbs.
Here's how I picked it up:
The first thing to do is to completely disassemble it. If you need instructions see my other thread: http://www.garagejournal.com/forum/showthread.php?t=93250
Clearly the paint has seen better days and needs to be removed. My method of choice is via electrolysis. It's cheap, easy, and loosens most of the paint making removal fairly easy. Here's the vise body taking a bath.
I let it soak overnight and then took it out this morning. I let it sit around all day while I was at work so a little flash rust has developed. Note how the paint has loosened over most of the body.
About 15 minutes of work with a hand held wire brush and a scraper ,for the stubborn paint, leaves me with this. Clearly, someone decided to weld on the back of the vise. I didn't see any cracks but they must have had some reason. Oh well, it doesn't affect how it works so I'm going to leave it as is.
After cleaning it up and wiping it down with paint thinner several times I hit it and several other parts with a coat of primer.
The dynamic jaw is currently in the electrolysis bath. I'll take it out in the morning, dry the slide, and spray the slide down with WD-40 to keep it from rusting during the day. Tomorrow night I'll post some updates.
I'm not sure about what color I want to paint it yet but I'm leaning back to red. Any recommendations?
UPDATE 3/1/11:
I got the dynamic jaw out this morning and sprayed the slide down with WD40 as planned. This is how it looked this evening. No flash rust on the slide.
I used the same method as before for getting the remaining paint off. Here it is masked off and ready to be primed.
Here's the dynamic jaw after being primed. It's always good to have another vise to lend a helping hand.
The swivel base is in the the electrolysis tank tonight.
UPDATE 3/1/11:
