Anti Vibration Pads (recomendation)
mayday0017
Houston Texas
I will be putting my new compressor in place tomorrow and I've never owned a big compressor before. All of the ones I see in pictures online people have antivibration pads on and most manufactures seem to sell them. What is recomended for this, I am sure there is something cheaper then they $50-75 the retail pads cost... Looking for something that will be locally available...
Recomendations?
LumpyMusic
Phoenix Arizona USA
I used discs, cut out of old tires, UNDER the feet. Old shock absorber bushings ABOVE the feet -
Lumpy
You Played on Lawrence Welk?
Yes but no blue notes. Just blue hairs.
www.LumpyMusic.com
Falcon67
Merkel, TX
Tractor Supply stall mat pieces and scrap lumber:
I don't know about Houston, but around here they don't sell hockey pucks. No hockey games in this climate.
JakeKohl
Greenville, SC
How about real isolation mounts for about $6ea?
http://www.mcmaster.com/#vibration-damping-sandwich-mounts/=hzrgg2
Magic. A few concrete anchors, nuts. Bam.
I used the 165lb rated ones (9376k26) but I would probably go up a little if ordering next time as they are a little soft and you can manually make the compressor swim around a little (possibly enough to make it tap the wall). Under normal running, however, they REALLY do a good job and the compressor doesn't wiggle much at all (and the floor feels nothing now). With the compressor on the original pallet on the floor (before the mounts), I could hear/feel the compressor running through the floor to my bedroom that is about 80 feet away (geesh, guess I left the compressor on). It's undetectable now.
DSC_3091 by Team Seacats, on Flickr
Gary S
Bismarck, ND
My compressor came bolted to a small pallet. I never removed it. It still sits on the small wooden pallet today.
mdbeck1
Norman, OK
Not many hockey games here either so I hit the internet and ordered a dozen. They worked so well that my neighbor commented he wanted some and I sold him the rest for what I paid for the whole set.
I think I ended up paying $1.50 each with shipping.
abstamaria
Manila
Not directly in point but perhaps relevant. My garage "rock" band (mostly guys over 60) comes over to play sometimes, so I had to try to learn a bit about acoustic treatment. The consensus regarding drums is to place the kit on a rubber mat to decouple the drums from the floor. There are specialist mats for those purpose, but some just use 1" interlocking mats available at hardware stores.
Raising the drums on a wooden platform doesn't work as well as the damping and insulation properties of rubber is needed. Also a platform tends to act as a resonating member and adds its own sound to the mix, often emphasizing and making louder certain frequencies. That seems to say use rubber or similar but not a wooden pallet under a compressor.
I'm thinking of switching to an upright compressor, so appreciate the many good ideas posted above.
Andy
pattenp
Virginia - USA
How does a hockey puck work as an anti-vibration pad? The hockey pucks I've come across are hard as a rock. You might as well just put the compressor on wood blocks.
BD1
north side
When you bolt it down with the isolators DO NOT tighten the nuts. Best just to double nut and leave loose. The anchor studs just keep it from walking. By tightening down solid the tank will crack at the feet by the weld. This comes from the installation manual.
ilovevocs
Toledo, Ohio
I paid through the face on whim for the ingersol rand "start up kit". It came with isolaters, oil, a 2' branded flex line, and an additional 2 year warranty for the pump. I can't remember what I paid but the when I saw the isolaters I felt like I was ripped off. It was one of those purchases I'll always regret.
W-Cummins
Iowa
Yep as dampeners the hockey pucks are not much use. I guess they would protect the floor from damage though. They would probably make nice floor glides if you wanted to push your compressor across the floor or ice :)
Buy real machinery mounts. They aren't that expensive. I have a Champion compressor with 80 gallon vertical tank and bought 4 of these:
http://www.use-enco.com/CGI/INSRIT?PARTPG=INLMKD&PMPXNO=5832313&PMAKA=325-6627
I have a lot of stuff mounted on these ( and larger sizes ) and their quality is good. They are not up to Royal machine mounts quality but they don't cost like them either! At under $7 each for 4 or more you can't beat them....
William....
LumpyMusic
Phoenix Arizona USA
beelsr
NE PA, USA
Mine lived like that for 8-9 years before I broke down and ordered some AV pads from someone here a few years back.
The pallet was nice because of portability. :beer:
PCO6
Newmarket, Ontario
I used 2 hockey pucks for each foot. I used a 3" hole saw to cut a 3/4" dense rubber pad that I sandwiched between the 2 pucks. I then lagged each foot to the floor and snugged them up - not too tight.
Jamie V
Atco, NJ
The title of this thread should be "low cost isolators" anything will work better then putting it on the floor.
The "best" option doesent mean it is the cheapest option.
I wouldn't use anything but this style
Shadowdog500
Down the shore
Who makes that style, and where do you get them?
Chris
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I would not feel safe with a foot of that design. The compressor is not anchored to the floor with those. Walk, tip, bump, blammo.
Lumpy
You sang all those car commercials?
You got it, Toyota.
www.LumpyMusic.com
A compressor DOES NOT have to be bolted to the floor. With a piece of rubber under the feet it will not walk, tip, or go bump in the night. If your compressor does do it though, then you had better be looking for another one that is better balanced.
The whole compressor feet thing has been beat to death before. Some choose to bolt theirs down and that is all fine. The isolation pads are to keep it from walking on concrete and to absorb what little vibration there is. At my shop we have mills, drills, lathes, large CNC's and none are bolted down. They all sit on isolation pads. Ours amount to nothing more than a piece of hardwood with a rubber material on top an bottom. It is bought in in a large sheet then bandsawed to the size needed. If the machine needs leveled, then two go under each foot with shims in between to level.
My compressor has been sitting in the same spot since day one sitting on four of those style of pads and has never moved at all. And it is not bolted down. I have what is very similar to what McMaster Carr shows http://www.mcmaster.com/#standard-vibration-damping-pads/=i071j0
fireguy
Motor mounts from 55-56 Chevy small block works good. I have mounted several small compressors with them. They are available at most parts houses.
enrare
This style of mount is what I have been considering since my floor is sloped and uneven. How well do these grip? My concrete floor has a smooth finish and the compressor tends to wiggle around on my current old hard rubber pads. I would like to avoid installing mounting studs in the floor.
boosteddsm92
MD
Horse stall mat.
+1, this is what I used also. Lots of mat leftover for other stuff!
Lumpy
You would have to hit my compressor HARD for it tip over, I'm talking hit it w/a car or something. Tipping it over is the last thing I'm worred about.
PT Doc
I decided to not raise compressor on specialized tall vibration posts simply for the reason that it would now be taller a maybe a bit more tipsy. I felt that hokey pucks were too hard and too small. I cut a horse stall mat into 24"x24" prices and placed 2 under the 600 pounder. No plans to bolt it down. 24 sq ft was $35. Plenty for other uses that I never thought of.
