Anvil Help
ARAMP1
Memphis, TN
I'm wanting to get an anvil for the shop, but have no idea how i would mount it. I've seen people attach them to tree trunks, but other than some way of finding a big tree and
doing that, what ways are there?
purevl
South City, STL
Small ones can be put on a trapezoidal plywood box filled with sand. Laminated 2x10s will work for a larger one, but it's a lot more work/expense than a stump. You can can build a steel base, but I'm not a fan. What size it is and what you plan to do with it make the biggest difference in how you mount it.
5lima30
Mountains of Western NC
An oak or hickory stump and some steel "staples" made out of 1/4" rebar and driven into the stump over the corners of the base is how I've seen them done. Check out I Forge Iron.com (blacksmithing forum) there is a whole section dedicated to anvils.
Larwyn
Texas
I have a cheap Russian made 110 pound anvil from Harbor Freight (discontinued). It is sitting on block of wood made up of 4x6's bolted together. Gravity is sufficient to hold it in place for my purposes so it is not attached in any way. I have used it that way for over 10 years and it has yet to float away.
Brad54
Hmmm... not a lot of hardwood trees down there in Florida, are there? And definitely no fire wood for sale... that was going to be my suggestion--find a place that sells firewood, and they'll have a couple hunks that haven't gone through the splitter yet.
Keep your eyes open for someone cutting down a Live Oak, and see if they'll give you a hunk.
Otherwise, I'd go with four hunks of 6x6 timber secured together, stood on end... it'll be a 1 foot by 1 foot square, however tall you make it. (anvil work surface should be such that a hammer held on it puts your elbow at a 90-degree angle)
-Brad
DocsMachine
I built a steel stand for mine. One, it gives me storage underneath, and two, it's easy to slip a hand truck under the legs (as I designed it to) to move it around.
The only benefit to wood is that it tends to help dampen some of the "ring" of a good anvil. Your HF anvil is cast iron, so that's not an issue. (It wouldn't ring if you threw it at a church bell.)
Wood is "traditional" simply because stumps and sections of log were easier and cheaper than any alternative in years past. Before 1900, premade structural steel was ghastly expensive, masonry wasn't much cheaper, and that just left wood.
Conversely, today the opposite is true. Anyone cutting a fair-sized Oak down- or any other good hardwood- likely isn't going to give it away. The wood is valuable, and some areas even have people going around after storms buying downed trees.
Lumber from the hardware stores is dirt cheap, however, and it's fairly easy and reasonably inexpensive to bolt several sections of 4x4 or 6x6 together with lengths of allthread.
But really, anything will do. I've seen anvils mounted to mortared pillars of rock, stacks of loose (as in, non-mortared) bricks or cinderblocks, even sat on old chairs. Whatever works for you.
Doc.
