JimCC
Hello all,
So, we've taken possession of our new house and I'm in the process of trying to work out how to squeeze everything in.
I've included some photos of the space I have to work with, which is 6850mm x 3160mm (approx 22' x 10' - I guess this is an American forum, and I'm asking for help, so I won't complain).
The space at the rear gives me roughly a metre between the back wall and the architrave. And I have 2450mm (8') under the steel beams and about 2350mm (7.7' - is that legit?) clearance under the pipes.
I have my eye on two Lista cabinets to go either end of the back wall and I'll build a bench to go across the whole space, with shelving above. The cabinets are the 36E units at 850mm high, so my bench would then be about 28.5" deep and about 34" high. I'm 5'11" with average reach, FWIW. I've also attached a rough drawing of the layout I have in mind. I drew this before I'd seen the house and taken measurements. Nothing like putting the cart before the horse, eh? I'll bet most of you would be much the same though.
After seeing on this forum many amazing examples of workshops I've gleaned a few ideas about storage up high around the walls, and will be filling the space with lighting and power points. I'll also be building drop-down benches to go on at least one of the two side walls. Oh and although not shown in the photos there is one small window on the right as you look to the rear.
I'll need to keep the place ****** tidy as one of the cars will be in there on a frequent basis. I suppose it'll help me keep things in check. Unlike my previous Tardis of a workshop.
I'll be using this area for anything and everything. Cars, bicycles, woodwork, misc. home renovation work, grinding, welding (in time). I'm going to go timber or heavy ply bench tops and will use thick gal sheets where required to protect the surface.
As far as vices, grinders, etc. are concerned I'm hoping to use a combination of receiver hitches on the main bench and post mounts on concrete-filled wheels. I can't think of any other way to make that work. And that movable mount would need to be shorter than the bench in order to be stowed away. This is going to be tricky...
I have a lot of gear given the size of this space. And I want more, such as a drill press for example. I don't know if I'm being unrealistic though. And I certainly need to store large items such as my mitre saw, jackhammer, etc. Although some of that can go in the living room I suppose where I think I might have to store the garden equipment and camping gear...
I'm just wondering if you guys have any suggestions on how I might make best use of this space. Anything you could offer apart from "buy another house" would be greatly appreciated.
