signcrafter
- Joined
- May 9, 2012
- Messages
- 12,468
I haven't done much concrete work, a few smaller things like fence posts and smaller slabs and stuff. Was watching some youtube videos and got to some concrete videos. Got me curious and have some questions.
So when pouring a slab or driveway you form it all up and the truck comes and starts dumping the slop. You spread it out and then screed it all to level it.
Then right away you use a bull float to smooth it all out right? When do you use a square bull float vs a rounded fresno float? Also you use a mag trowel to do the edges right? Do you do edges after the bull float or before or doesn't really matter?
After you float it all you let it set up a little bit right? I know it depends on many things but roughly how long do you wait for it to set up? Or how do you know when it's set up enough? Then you have to trowel the whole thing? Either using a power trowel or by hand? Can your really do a whole 24x24 slab by hand or is a power trowel a must? If you do it by hand what type of trowel do you use?
Then are you all done unless you want a broom finish or something else? I saw some spray a chemical or something on it from a pump up sprayer. What is this and when/why would you use it?
Any other steps I'm missing? I don't have any cement projects planned and I don't think I would ever try a decent sized pour without some experienced help but watching the videos got me curious about these things.
