Matt Harwood
Hi guys,
I'm having a discussion with a friend about compression ratios vs. cylinder pressures and perhaps we're thinking too much and confusing ourselves. It's been my experience that boring and stroking a motor has the net effect of lowering the compression ratio because the volume of the combustion chamber is increased by the wider bore, which offsets the added volume of the enlarged cylinder. Of course it varies from engine to engine, but on every bored motor I've ever built, I had to deck the heads to bring compression back up to desired levels.
But my friend counters by saying that it's merely the quench area that is affected by boring, not combustion chamber volume. Since the compression ratio is the ratio between the swept area and the combustion chamber size, compression should go up as swept area goes up, correct?
Then he asks, "Do dished or crowned pistons actually change the compression ratio, or just the combustion chamber "pressure?" I think the ratio actually remains constant, since the volume at bdc is increased or decreased as much as the volume at tdc."
I would argue that since a domed piston takes up a greater proportion of the combustion chamber compared to overall swept volume, that it doesn't cancel out and compression goes up. A dome on a piston may take up 40% of the combustion chamber's volume, but only 5% of the total swept volume of a cylinder, so as a ratio, they don't cancel out and compression goes up.
Can anyone elaborate? I thought I knew what I was talking about, but now I'm all confused...
Thanks.
Thanks.
