SouthernIllinois
- Joined
- Jan 14, 2024
- Messages
- 1,777
Thanks for the linkIn my opinion, I find that the spiral extractors can put a great deal of pressure on the offending bolt especially as you turn it out. This can make bolt removal more difficult. You are better off with straight extractors that do not exert any more outward pressure as you turn them.
Snap-on Store
shop.snapon.com
The Snap-on set lists as out of stock.... Looks like the Ridgid.Thanks for the link![]()
Thanks - The Rigid set says it's made in the US as well, same as the Blue Point setThe Snap-on set lists as out of stock.... Looks like the Ridgid.
The RIDGID 35585 10 Screw Extractor Set, 1/4-inch to 1/2-inch (6-13mm) Broken Screw Extractor. I paide $125 for mine. I see that Zoro has it for $143, SupplyHouse for $118, and Amazon for $136.50.
My only complaint is that it uses right hand drill bits and I would prefer left hand. I do not care enough that I replaced my right hand bits with left hand bits, but I might eventually do that. And if I replace one, I will replace them all to avoid confusion. My brother-in-law claimed that more often than not just using the left handed bit is enough to get out the fasteners he dealt with.
My guess is that RIDGID makes the Snap-On, but that is just a guess.
Look at Irwin 11119.
Check out the insert in the picture for the big set on Amazon, and notice that the larger sizes of extractors are made for really big bolts. And then maybe get a smaller set.Have you forgotten that this is garage journal, You want the big set
Not the Small set
I almost bought this (not needed because I own a few different sets) set because...We really like the Norseman 35484 with both lefthanded bits and straight flute extractors from the big river for 60 bux. They have worked much better than any spiral sets we had before. A word of caution...they will also break off in stuff and then a carbide ball mill in a die grinder is the only escape. We had this problem just this week on a $100K boom truck. Thought it was moving and then SNAP! I don't think a more expensive set would have worked either. The snapped bolt head was basically friction welded from the boom to the cylinder due to the movements involved in normal operation of extending and retracting the boom.
My Brother-in-law dealt with a bunch of these and he said the same thing.... More often than not the left hand drill bit took it out. He was was mostly dealing with production line equipment so mostly not in a car undercarriage or farm equipment with a ton of rust.Not working on much rusty old stuff I find that the left hand drill bit does most of the extractions by itself.
lg
no neat sig line
I've also have had good luck with left hand drill bits . I've also added a few left handed center drill bits.When your in a tough situation, it's nice to have optionsMy Brother-in-law dealt with a bunch of these and he said the same thing.... More often than not the left hand drill bit took it out. He was was mostly dealing with production line equipment so mostly not in a car undercarriage or farm equipment with a ton of rust.
That's a great set. If I remember correctly, it's made by Ridgid.. My only complaint was that the drill bits are not left-handed...
