Any Foredom Experts?
Richard D
Texas City, between Houston and Galveston
I bought a Foredom flexible shaft tool used. There is a piece missing on the end. I've checked out their website but I'm unsure what I need. The threads are about 9/32.
I also see, on their website, replacement parts for various hand pieces. How can I tell which hand piece I have? I don't see any markings on mine.
brooker
That's an older #88 handpiece, now sold with a slightly modified base as the #8 general handpiece. Yours is missing the chuck.
Inexpensive replacement piece HP44A from Foredom. Screws onto front end and secures the collet and burr.
http://www.foredom.net/hp44A.aspx
You will need appropriate collet(s) for the shaft diameter of the burrs you will be using. Check with Foredom whether the chuck needs a key, but with that type it's usually sufficient to be hand tightened.
The sliding sleeve is just a protector to keep fingers away from the rotating chuck. Sometimes easier and more control to work without the sleeve.
R
Richard D
I just watched a few interesting videos about hand pieces. Do I have the quick change shaft on mine? I am considering a #30 hand piece, as there are lots of accessories for it, as well as a #44, since it takes 1/4" burrs; that's the size burr I see myself using the most, porting cylinder heads, and general metalworking. I'm not a jeweler, dentist or stone-worker.
brooker
The quick change handpieces have a spring loaded or rotating lever that allows burr changes without needing to manipulate the chuck or find a chuck key. Users such as jewelers that might need to change between many different burrs repeatedly like these. But they are limited to 3/32 shaft burrs only. For relatively light duty. precise, tiny work. Your handpiece is not a quick change model.
The 30 and 44 handpieces are much more heavy duty, and are not interchangeable with the full line of Foredom equipment. They require a different model motor and flexible shaft than the one you have. These are probably more appropriate for engine type work, carving, etc, things that need more time, pressure and torque without bogging down. This is where people decide between these electric tools vs. small or mini air die grinders. Also, the 30 has a traditional style 3 jaw chuck, a small Jacobs actually, size 0, but only accepts up to 5/32 burr shaft. The 40 takes collets, up to 1/4 available for the bigger burrs.
However, the handpeice you have is still a great tool, and a nice
step above Dremel. Once you use it, a Dremel seems like a toy, in my opinion. Start out with it, see how you like the feel of it. It gets better as you move up through their product line. But after you have used it, you're in a better position to decide what kind of upgraded hand piece might be even better for your particular needs.
brooker
CC motor was discontinued but is still widely used. I think some were 1/8 hp, some 1/10. Your older shaft might have a square drive which is needed for the 30/44 hand pieces. You can pull the hand piece off the shaft and check of the cable.
Also, some foot speed controls are interchangeable with motors and hand pieces, some not. There have been so many variations and combinations over the years that you need to check with Foredom, esp. if you can still find a serial # on the motor. Then they can direct you accurately in putting together a good setup, that will be electrically and mechanically stable.
One of the problems with these tools is that you can't just go in somewhere to see and feel the equipment, and match to your existing parts. No place sells the full line retail. Maybe just a piece here and there. You will need to talk to a tech at Foredom for perfect advice.
