Any guesses?
Ch3No2
Here is a project I have been working on....
Any guesses?
C
Ch3No2
There is an engine in there somewhere....guess I should have been more specific...type of vehicle/application?
CNGsaves
KS and OK
Bonneville Salt Flat turbo intercooled project??
Long and narrow . . . . great for aerodynamics ??
C
Ch3No2
Almost...yes Bville...no intercooler just a PSI screw blower mounted upside down ahead of the engine with a crank driveshaft to the pulley assembly. Butterfly shaft cut for a progressive style blade opening...
C
Ch3No2
The one in the avatar goes in this...
airrj
Wide Wonderful Wyoming
I recognized the PSI screw charger. Those things turn scary fast. I only got to play with one of those on the dyno years ago. Very interesting looking build!
Rural53
Tauranga, New Zealand
While we are talking boat motors...
https://scontent-syd1-1.**.fbcdn.net/hphotos-xtf1/v/t1.0-9/s720x720/11014809_1169776179709381_7858194532935587789_n.jpg?oh=961e168e0fdf47aedd48fbc6aba65960&oe=56D947AA
For a ski racing boat.
shawnspeed
Is the B'ville motor CH3No2 powered??....LOL...I love FUEL.....the burn of the nose hair, and the movement of your organs upon clearing it's "throat" is like no other ....
C_F
Utah...SNOW BLOWS!
Dayumm!:drool::rocker:
CGT80
IE, SoCal, USA
I will bet those poor pistons look tiny compared to the height of that boat engine. It looks like you have a liquid cooler under the blower. Will it run lake water or does it have a closed cooling system with a heat exchanger?
It was easy to see that the first post was a blower mounted upside-down in front of an engine and I figured it was to keep the engine short. I was thinking it would fit under an engine cover in a boat, but a land speed car makes sense as well.
Rookie2
Western Pa.
Low profile for sure ! Kool !
But that drive shaft with overdrive isn't going to survive unless you plan on crouding up to 10K.
zmotorsports
Northern Utah
Nice. I stumbled across your shop build the other day. Are you building this in your home shop? By what little bit I can see the background doesn't look like your home shop.
Mike.
Rookie2
Western Pa.
Land speed record challenge
Scratch that ... Water speed record challenge !
