SteelHorseHD
Hey guys! I recently acquired two Modine Hydronic Heaters from work that they were just going to throw away. What is wrong with them?!?
I have an outdoor wood burner at home and was hoping to hook these two units up in my garage wich is a 36x45 well insulated pole barn with a concrete slab.
I am hoping that they will work but I really have no clue as to what they are capable of putting out as far as BTU's go. The heat exchanger on them is around 12x12 inches. I am hoping that one of you has some sort of idea about what kind of heat they will put off. I was thinking somewhere in the area of 25-30K BTU's each? If it helps, I usually run my boiler between 170-180 degrees. Here are some pictures, thank you!
