It is exactly what you suggest.looks like a follow rest, it follows along behind the cutter to keep the turning shaft from bowing.
Yup, his next picture made it right for me.^^^ I think it's just how the poster oriented it on the lathe
Apparantely its been im my small town since the beginning of time. With the lack of cleaning ive given it may combust. Ways are a little sloppy. Came with a pallet of tooling/multiple steadys/3 jaw/4 jaw chuck.I hear they spontaneously combust, I can take that safety hazard away for you.lol
Sadly you see far too many formerly decent machines utterly ruined either in home shops or light industrial settings because no one ever cleans and oils them.And, no offense, but the ways on that thing- the whole lathe- are filthy. That mud is basically acting like lapping compound. Please do yourself a favor and clean those ways thoroughly, including, if possible, under the carriage, and re-lube them with fresh, clean oil.
Old machines like that live in oil- get a trigger oiler and lube the bejeebers out of it every time you use it. Buy more bejeebers if you need to.You cannot over-oil it. Fresh oil lubes the parts then drips down into the pan- and carries dirt, grit and swarf down with it.
And don't get ******* with the old arguments about the "correct" oil- technically yeah, you want "way" oil for the ways (typically Vactra #2) and plain oil for the gearbox and the like, but in your case, any oil is better than what you have. Buy a trigger oiler and a quart of 10W-40, and lube anything that moves.
Then wipe off the dirty oil and lube it again. Keep doing that until the oil stays clean.
That machine has already lasted for decades- it'll last many decades more with good cleaning and lube.
Doc.
Amazing, but probably true..! What a neighbour of mine would call "engineering brutality"..I did hear of one agricultural workshop that after effectively destroying their lathe after 40 years of absolutely no maintenance decided to build the very worn bits of the bed way up with weld and then grind it back to somewhat straight with an angle grinder.
Although my little old BoxFord lathe is in a 'clean room' at one end of my workshop and already shiny and dripping with oil and ACF50, I get the idea that as it's a rainy cold afternoon here dutchgray and myself will both be out in the workshop brushing and splashing and wiping fresh oil around on our lathes!And, no offense, but the ways on that thing- the whole lathe- are filthy. That mud is basically acting like lapping compound. Please do yourself a favor and clean those ways thoroughly, including, if possible, under the carriage, and re-lube them with fresh, clean oil.
Doc.
I actually had a rare Saturday at home today as I am just really tired, all day yesterday was spent hauling my new to me 1972 Dean Smith and Grave 1307 x 40 out of the workshop of its previous owner, then getting it skated in to my workshop.Although my little old BoxFord lathe is in a 'clean room' at one end of my workshop and already shiny and dripping with oil and ACF50, I get the idea that as it's a rainy cold afternoon here dutchgray and myself will both be out in the workshop brushing and splashing and wiping fresh oil around on our lathes!
These same people also recently scrapped a large radial arm drill that was in working order (I believe they almost never used It) because they couldn't be bothered trying to sell it.Amazing, but probably true..! What a neighbour of mine would call "engineering brutality"..
Thanks for the info on how to setup the follower. Im going to clean it up and get it setup.Okay, that doohickey is called a "follow rest", as it follows the tool. (A 'steady rest' stays in place on the bed and holds the work in one spot.)
The section of dovetail on the right unbolts. Or at least loosens- loosen that, slide it onto the dovetail from the back, get it into position, and re-tighten the two bolts. The dovetail section is pulled up and clamps it in place.
The whole upper assembly moves left and right on the dovetail part, so you can align it in relation to the tool. You can have it follow behind the tool (the tips ride on the turned portion) or you can run it ahead of the tool, where the tips ride on the unturned portion.
You'd want it to follow (ride on the just-cut surface) if you're doing something like cleaning up hot-rolled, with a rough-ish surface or a lot of scale. Or a cast rod, or any other situation where the surface is less than smooth and true.
Doc.
www.dutton-lainson.com
