You're looking at a lot of vibrating weight 8 feet over head. I personally don't like the idea, as it seems like an accident waiting to happen. How do you plan on picking it up to place it on this shelf, fork lift?
If you're head over heels in wanting to do this, I would skip the 2x's and build it out of super strut. You can have feet and bolt them into the floor to prevent walking. I would run 2 pieces to the joist over head which will help with stability. Bolts, lock washers or loctite would be used for fastening.
What is wrong with keeping it on the floor?
bob
Don't want to waste the space on the floor.. we have the entire floorspace around the garage used up.. cabinets all down one side, lathe and pallet rack along the back, and workbench all down this wall. I'd rather not use the floor space we may have in the pallet rack area for a compressor, and although we could put it up on the pallet rack, I'd rather use this wasted space in the opposite corner.
I'm not worried about having it up high, as long as it's anchored, it won't be any worse than standing under the lift that is 2ft away with a 4000lb vehicle on it.
As for picking it up, I have access to genie lifts at work that will pick it up no problem
If I were going to hang it, I'd use threaded rod and strut...which is the industrial product designed to do exactly what you are doing...hang heavy things from the ceiling (just make sure the struts on the ceiling is lagged into several joists, to share the load. Then use strut nuts to attach the correct lengths of threaded rod, down to a couple of other pieces of strut, which will either attach directly to the pads of your machine, or support a heavy (plywood?) platform on which you can set your compressor.
I like the "tall table on legs" idea, simply because it decouples the air compressor from your walls (reduces noise). If you do this, make a 'box' out of the top (put plywood on top and on bottom, and stuff it with insulation, or something to reduce the noise--maybe even some dynamat covering 20% of the pieces of plywood). You may still want to tie this into the wall, just to make sure it doesn't fall off.
think about all your connections, before building whatever shelf system you are going to build (electricity, connections for air hoses, drain for the bottom of the tank).
Looking forward to seeing how you choose to do this...post pics please.
Kev
LOL, I never gave unistrut a thought.. and we have some on the other side of the garage holding the heater!
I want to rubber mount stuff to isolate, as well as anchor it to the wall with a loose cable so incase all the bolts fall out, it can't walk all the way off the platform.
The reasons for wanting to put it in this corner are many.. the main electrical panel is right there, so it'll have to go about 3ft for power, there's access to outside to drain the water out, and the air lines can go right along that wall as it will be over the work bench, and right next to the lift. I'd run a piece of hose over to a length of pipe, have a few drops, as well as run a piece out for a spool the ceiling for working under the lift
If we do this, pics will definately be posted.. probably in the build thread in my sig too
I'd make a triangle corner shelf so it's anchored to 2 walls instead of cantilevered out from the 1 wall.
Hadn't thought of this, but I think with the ~3ft of space to the garage door it would eliminate this option since it's a horizontal compressor. It would probably work if we had a stand up compressor though
